Installing grub2 fails on my system (10.4 64Bit) with:
/usr/sbin/grub-probe: error: cannot find a GRUB drive for /dev/sdaq1.
 Check your device.map.
Checking device.map, it only lists hd0 to hd25 corresponding to sda to sdz. Recreating the device map produces the same result. How do I get grub to recognize /dev/sdaq1.
Note: The machine has many, many devices; sdaq is the correct drive.
user7054
  • 203
You need to patch grub-installer.
See bug report 776633 for a patch:
Index: grub-installer-1.60ubuntu3/grub-installer
--- grub-installer-1.60ubuntu3.orig/grub-installer  2011-05-03 12:00:57.553509999 -0700
+++ grub-installer-1.60ubuntu3/grub-installer   2011-05-03 12:04:02.873000831 -0700
@@ -286,7 +286,7 @@
     /dev/loop)
    disc_offered_devfs="$bootfs"
-    /dev/[hsv]d[a-z]|/dev/xvd[a-z]|/dev/cciss/c[0-9]d[0-9]*|/dev/ida/c[0-9]d[0-9]*|/dev/rs/c[0-9]d[0-9]*|/dev/mmcblk[0-9]|/dev/ad[0-9]*|/dev/da[0-9]*)
+    /dev/[hsv]d[a-z]|/dev/[sv]d[a-z][a-z]|/dev/[sv]d[a-z][a-z][a-z]|/dev/xvd[a-z]|/dev/cciss/c[0-9]d[0-9]*|/dev/ida/c[0-9]d[0-9]*|/dev/rs/c[0-9]d[0-9]*|/dev/mmcblk[0-9]|/dev/ad[0-9]*|/dev/da[0-9]*)
    disc_offered_devfs="$prefix"
grub-installer is probably not on your system (since after it's in installed there's not really need for it to stay ;) ). This is the package it concerns: http://packages.ubuntu.com/source/natty/grub-installer so you'll probably find it on the install medium...
Here's a quick how to on remastering your own CD: How can I easily remaster Ubuntu?
Rinzwind
  • 309,379
