Put Clonezilla ISO file in root / directory.
Open the terminal and run:
sudo nano /etc/grub.d/40_custom
Insert the following text at the end of the file:
menuentry "Clonezilla Live" {
set isofile="/clonezilla-live-2.2.3-10-amd64.iso"
loopback loop (hd0,1)$isofile
linux (loop)/live/vmlinuz boot=live live-config nolocales edd=on nomodeset
ocs_live_run=\"ocs-live-general\" ocs_live_extra_param=\"\" ocs_live_keymap=\"\" ocs_live_batch=\"no\" ocs_lang=\"\" vga=788 ip=frommedia nosplash toram=filesystem.squashfs findiso=$isofile
initrd (loop)/live/initrd.img
Save file, exit and open GRUB's config file:
sudo nano /etc/default/grub
Comment out the line GRUB_HIDDEN_TIMEOUT=0 so it looks like:
#GRUB_HIDDEN_TIMEOUT=0
Make sure that the line GRUB_TIMEOUT=[some number] has a number >0, for example, 10
Save file and exit and run
sudo update-grub2
ADDITIONAL NOTES:
⠀- /clonezilla-live-2.2.3.10-amd64.iso -- change the name of iso file to match the one you have.
⠀- (hd0,1) may be different for you depending on how you installed Ubuntu.
(hdX,Y) X = hard drive #, Y = partition.
⠀You can also see my YouTube video for the above procedure: Boot Clonezilla ISO from Grub2 Menu.
