Skype keeps starting at startup without my permission. I don't want it to start minimised, there's already a solution for that, I want it not to start. But there isn't a single setting in Skype's options, and Skype is not in my startup applications.
EDIT — as requested, a screenshot of the "session" tab in my Session & Startup settings:
Screenshot
And the weird output of that "grep -lir 'Skype' ~/.cache" command, giving me something about Kingsoft Office:
/home/wolf/.cache/logrotate/status
/home/wolf/.cache/Kingsoft/wps/http/cache_c8034f79bfb82e94e16ff8ebebcfff38262f0359.cache
/home/wolf/.cache/Kingsoft/wps/http/cache_030f47fb47e37a138cb0973e152475a098eeee54.cache
lyra
  • 417
  • 13
I had this same issue (and cross-posted this answer). I was able to prevent it from starting automatically by removing skypeforlinux.desktop from ~/.config/autostart/. I'm using lubuntu; the location of your autostart folder may vary. You can find by using:
$ locate skypeforlinux.desktop
You'll really only want to delete the copy in the directory called autostart, otherwise you won't be able to start the app from the icon.
I'm assuming that the next time you actually, intentionally run Skype (I hope, for the sake of your sanity, that this day is far in the future) that it will try to put that file back. In which case you might have to delete it again or scour Skype for the setting that will prevent that behavior.
sudo apt-get uninstall skypeforlinux
I don't really need Skype as there are plenty of other options. If they feel the need to start it automatically on login, I feel the need to remove it from my system.
timbo
  • 333
Three possible solutions, from least to most invasive:
  1. Exit all programs, then open Sessie en opstart and click Sessie opslaan. This ought to overwrite a session file named something like ~/.cache/sessions/xfce4-session-$HOSTNAME:0 which may contain a reference to skype.
  2. Manually edit any files named things like xfce4-session-$HOSTNAME:0 in ~/.cache/sessions/, changing any "skype" to "echo"
  3. sudo mv /usr/bin/skype /usr/bin/spyke – it seems to run fine with a new name, but any calling scripts should fail to find it. You'll have to change/make a new .desktop file if you want clickability.
unhammer
  • 2,321
