I got myself a Transcend 64GB SSD (model number: TS64GSSD340).
I put the SSD into a tiny netbook I have. Netbook specs are:
- Make/Model: Acer V5-123
- CPU: AMD E1-2100 with Radeon HD 8210
- RAM: (came with 4GB, but, I upgraded to 8GB because I put /tmp into tmpfs)
This netbook came with Windows 8.1, but, I removed that entire HDD and put the Transcend 64GB SSD in its place. Then, I installed Xubuntu 14.04 onto the SSD.
Firmware info for the Transcend SSD is as follows:
$ sudo hdparm -I /dev/sda | grep -i firmware
Firmware Revision: SVN263
I checked online and couldn't find any (new/updated) firmware files for this drive.
Based on various notes found all over the web, I have done the following ssd optimizations:
- Left about 4GB of unused + unallocated space on the drive at the time of creating partitions (i.e., at the time of installation)
- Added noatime for / to the fstab
- Added "fstrim -V /" to rc.local and yes, my rc.local is always executable because I have a bunch of other things i do in it
- Removed the fstrim from cron weekly
- Made sure that the ff cache is 0
Now, the real issue is that the drive is DEAD SLOW. I mean, booting up takes over a minute. Starting firefox, terminal, gedit, etc, take a lot of time. (Before you jump onto me ... yes, I did install a lot of software, including my favorite editor gedit, onto this system).
My only point of comparison at this point is time is my other notebook (fujitsu, core i3, 8GB, 500 GB magnetic HDD) running Xubuntu 13.10. That notebook boots up in under a minute, possibly in half a minute! But, this SSD netbook running Xubuntu 14.04 neither boots up quickly nor does it start apps quickly. Clearly, my assumption that an SSD will speed up things was wrong!!??
Additional info: Xubuntu kernel is 3.13.0-30-generic (64 bit).
Update # 1
I did two tests mentioned in the Arch wiki SSD Benchmarking page, as suggested by @Tuknutx. Each test was done four times:
- "sudo hdparam -Tt /dev/sda" generated "average cache reads at 1030.7125 MBps" and "average buffered reads at 362.2075 MBps"
- dd read test with empty buffer cache generated "average reads at 383.5 MBps"
I put together the following script (based on the contents of Arch wiki SSD Benchmarking page) to do the "dd read test":
# first create a file
dd if=/dev/zero of=./tempfile bs=1M count=1024 conv=fdatasync,notrunc
for i in 1 2 3 4
do
echo "Run number ${i} ..."
# then clear the buffer cache
sudo bash -c "echo 3 > /proc/sys/vm/drop_caches"
# now read the file
dd if=./tempfile of=/dev/null bs=1M count=1024
echo
done
I have not performed other tests mentioned on that page.
Update # 2
I did one thing after completing those tests: I had put "vm.vfs_cache_pressure=50" into my /etc/sysctl.conf, but, now I removed it. After that change and a reboot, the system seems to be booting up (from "Acer" logo to auto-login") in just under 30s. But, my assumption was that things should be even faster than that because my magnetic HDDs are giving me those sort of boot times!!
Update # 3
I still have to follow @Lekensteyn suggestion of moving the SSD onto the core i3 notebook. I will do that soon and report here.
Shouldn't SSDs be blazing fast?
Given all that info, what would you recommend I do to speed up the drive.
I would appreciate if you give me specific directions (text + commands) to run to speed up the drive.
Update # 4
People! Thanks a lot for your helpful replies. But, this SSD was so PATHETIC that I threw it out of the window ... no kidding. Let me know how to close this question as there is no point in wasting our time on this pethetically low quality product produced by Transcend and sold by Flipkart in India.
Adios! Peace!
