Im using Ubuntu and I cannot find /sbin/hotplug. Did anything replace it?
How does it handle hotplugging? I read that kernel calls it for notifying user space when an hotplug event happens. I also checked /proc/sys/kernel/hotplug , but its empty
Asked
Active
Viewed 4,041 times
Pabi
- 7,429
Zhani Baramidze
- 181
From https://www.kernel.org/doc/pending/hotplug.txt we can read:
... Linux provides two interfaces to hotplug; the kernel can spawn a usermode
helper process, or it can send a message to an existing daemon listening to a
netlink socket.
and:
It's possible to disable the usermode helper hotplug mechanism
(by writing an empty string into /proc/sys/kernel/hotplug)...
So, if your /proc/sys/kernel/hotplug is empty that means you/ubuntu are not using the 'usermode helper hotplug mechanism'.
Instead udev, as the "successor" of the old 'usermode helper hotplug mechanism', listens on a netlink socket and gets notified by the kernel about hotplug events.
I hope this helps.
mofoe
- 51
