The command menu of Aptana Studio 3 is not showing in a Ubuntu 14.04.
Other menu items are working fine. Can anybody suggest a solution for this issue?
Eliah Kagan
  • 119,640
SAMUEL
  • 121
Had the same issues here. Solved it by installing the Jave RE from Oracle. Downloaded the archive from the Oracle site and then followed the procedure as described below.
  • Extract the folder from the archive.
  • Copy the folder to /opt/Oracle_Java/ (I had do create this folder).
  • Run the following commands. (Note: Make sure to change the VERSION according to the version you download from Oracle).
    sudo update-alternatives --install "/usr/bin/java" "java" "/opt/Oracle_Java/jre1.8.0_VERSION/bin/java" 1
    sudo update-alternatives --install "/usr/bin/javaws" "javaws" "/opt/Oracle_Java/jre1.8.0_VERSION/bin/javaws" 1
  • Then run these commands:
    sudo update-alternatives --set "java" "/opt/Oracle_Java/jre1.8.0_VERSION/bin/java"
    sudo update-alternatives --set "javaws" "/opt/Oracle_Java/jre1.8.0_VERSION/bin/javaws"
After installing Java, you can run Aptana.
You should start Aptana with export UBUNTU_MENUPROXY=0. I use a small script to start it (make sure to adapt the path):
#!/bin/bash
/path/to/Aptana_Studio_3/AptanaStudio3
Eliah Kagan
  • 119,640
Mike
