I'm new to linux systems and I can't really understand why wee need two operators that can redirect output: pipe as | and ouput redirection operator >? Can't we just always use the second? Most of the times I see that the pipe is used if multiple commands are chained together. If however, the output is redirected to file, as in echo 'hello' > filename, the output redirection operator is used. What am I missing here?
- 3,851
I believe the < > operators are used for reading/writing files whereas the | symbol is used for piping the stdout of one command to another.
cal | less
lets you view the output of cal in a command called less.
cal > less
puts the output of cal into a file called less.
- 290
|are used to send the output of one command as input to the another command which comes next after the pipe symbol.$ echo foo | grep -o 'f' fTo redirect the output of one command to a file , you may use an output redirection
>operator.$ echo foo > file1It writes
footo file1. You don't need to manually create that file.If you want to redirect the output to many files then you have to use
teecommand.echo foo | tee file1 file2It writes
footo file1 and file2. You don't need to manually create that files. Now the file1 and file2 contains only the stringfoo.
- 80,446
There's a lot of talk about output redirection but I thought this question was about input. I'm going to ignore > and >> because they've nothing to do with input. Instead I'm going to focus on <, <(...) and |:
<expects to read from a file intoSTDINwhile,<(...)provides a file handle to theSTDOUTof a command (...here)|pipesSTDOUTfrom one process into theSTDINof the next
So the < isn't directly equivalent to a pipe (it's reading from a file) and the <(...) is reading from the right place, but it's giving a file handle as an output. You need to combine them to offer an equivalent to a pipe.
a | b
< <(a) b
Just reading that, I hope that full explains why the pipe exists. It's much more readable.
- 299,380
The key point to remember is that pipes are inter-process communication device that allows two processes ( and that's what commands really are) to exchange data, while redirection operators are for manipulating where particular process writes.
In the video Unix Pipeline, the creator of awk language and one of the original people who worked on AT&T Unix Brian Kernighan explains:
First, you don't have to write one big massive program - you've got existing smaller programs that may already do parts of the job...Another is that it's possible that the amount of data you're procesing would not fit if you stored it in a file...because remember, we're back in the days when disks on these things had, if you were lucky, a Megabyte or two of data...So the pipeline never had to instantiate the whole output
As you can see, within the context which the pipelines were created, they actually were not just communication device, but also save storage space and simplify the development. Sure, we can use output/input redirection for everything (especially nowadays with storage capacity being in the range of Terabytes), however that would be inefficient from the storage point of view, and also processing speed - remember that you're directly feeding output from one command to another with |. Consider something like command1 | grep 'something'. If you write output of command1 first to a file, it will take time to write everything, then let grep go through the whole file. With pipeline and the fact that the output is buffered (meaning that left-side process pauses before right-side process is ready to read again), the output goes directly from one command to the other, saving time.
It is worth noting, that for inter-process communication, there's a use case of named pipes, to which you can use > operator to write from one command, and < to let another command read from it, and it's a use case where you do want to have particular destination on filesystem where multiple scripts/commands can write to and agree on that particular destination. But when it's unnecessary, anonymous pipe | is all you really need.
- 107,582
