I tried to install imagemagick using following command
sudo apt-get install imagemagick --fix-missing
But while installing I get following error
nginx-full : Depends: nginx-common (= 1.4.7-1+precise0) but 1.6.0-1+precise0 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I tried to remove the nginx using sudo apt-get remove nginx command but getting same error how can I resolve this issue.
Edit By referring this link output ofdpkg -l | grep nginx
iU  nginx                                  1.4.7-1+precise0                                    small, powerful, scalable web/proxy server
ii  nginx-common                           1.6.0-1+precise0                                    small, powerful, scalable web/proxy server - common files
iF  nginx-full                             1.4.7-1+precise0                                    nginx web/proxy server (standard version)
output of dpkg -S $(which nginx)
dpkg-query: error: --search needs at least one file name pattern argument
Use --help for help about querying packages.
Thanks in advance.
Run :
sudo dpkg -r nginx-common
If it is successful or not run:
gksudo gedit /var/lib/dpkg/status
In the resulting gedit remove the whole section starts with:
Package : nginx-common
then run the installation
