I have Ubuntu 14.04 32 bit. I am trying to compile an application from source code. It gives me an error message during linking in make process though ./autogen.sh and ./configure passed without errors. I got this error undefined reference to g_variant_parse_error_quark I read that that function g_variant_parse_error_quark added to glib2 in 2.39. I checked out installed packages and found that libglib version is 2.40.0 in my system. However
 pkg-config --modversion glib-2.0
reports 2.38.2
It appears that I have at least two different glib2 installed. I might have manually installed glib2 from source in the past.
How can I fix that problem and let my system use correct latest library?
kenn
  • 5,232
As I guessed it stemmed from conflicting multiple libraries. When I run
 echo $PKG_CONFIG_PATH
it returned empty line
Then I searched for
  locate glib-2.0.pc
and I got
  /usr/lib/i386-linux-gnu/pkgconfig/glib-2.0.pc
  /usr/lib/i386-linux-gnu/pkgconfig/spice-client-glib-2.0.pc
  /usr/local/lib/pkgconfig/glib-2.0.pc
I also run
  pkg-config --debug --modversion glib-2.0
to find which directories were searched for
I looked in the glib-2.0.pc files and checked out the version numbers.
I located the correct glib-2.0.pc file
then I run
  export PKG_CONFIG_PATH=/usr/lib/i386-linux-gnu/pkgconfig/
after then ./autogen.sh and make
went smoothly
kenn
  • 5,232
