-1
When I run command $ sudo nautilus, I am getting the following error message:
** (nautilus:2611): WARNING **: Couldn't connect to accessibility bus: Failed to connect to socket /tmp/dbus-JjKUQBOPpS: Connection refused
(nautilus:2611): Gtk-WARNING **: Failed to register client: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
(nautilus:2611): IBUS-WARNING **: The owner of /home/nit/.config/ibus/bus is not root!
How could I solve it?
Parto
  • 15,647
Kubuntu doesn't use Nautilus as its file manager but uses Dolphin instead. Therefore,
sudo nautilus
OR
gksudo nautilus
gives error.
Please, type
sudo dolphin
OR
gksudo dolphin
to get root privileges for your file manager.
Raphael
  • 8,135
Do not use sudo directly with graphical programs.
Try either:
gksudo nautilus
# or
pkexec env DISPLAY=$DISPLAY XAUTHORITY=$XAUTHORITY nautilus
You'll probably need to install gksudo first, if you're going by the first method:
sudo apt-get install gksu
muru
  • 207,228
