13
I really miss the graphical "Services" tool from older versions of Ubuntu, but I understand why it had to go. I always have terminals open anyway, so I use (because I have to now, I guess) service --status-all to see what services are running. This would be ok except that the command produces output like the following:
 [ + ]  winbind
 [ ? ]  wpa-ifupdown
 [ - ]  x11-common
I'm guessing that those symbols mean something like listening, blocked, or stopped, but which is which? More importantly, why doesn't the man page say?
ændrük
  • 78,496
koanhead
  • 6,547
To provide a shallow and unsatisfactory answer your first question:
  • The command service --status-all literally runs service <name> status for each service that supports the status command. Convention is for these to return success if the service is running and an error otherwise. A [ + ] is drawn upon success and a [ - ] upon error.
  • The [ ? ] is drawn for services that don't mention a status command in service <name>.
As you might have anticipated, I learned this by reading the source code.
To address the real issue—the lack of documentation—I suggest filing a polite bug report about the manpage on Launchpad. ubuntu-bug sysvinit-utils should get you started.
ændrük
  • 78,496
11
services-admin was removed from the default installation some releases ago due to the fact that it was unable to handle Upstart jobs.
In 10.10, a utility to manage services has returned: jobs-admin will be able to control and configure both Upstart and System V jobs/services. If you'd like to give this a try now, check out the jobs-admin/jobservice PPA.
As for the symbols in your question, I believe + is running/enabled, ? is configured to start but may not be currently running (run-once, maybe), and - is likely disabled or not running.
Disclaimer: I am the developer of jobs-admin and jobservice and worked on it as a summer of code project for Ubuntu. It is not available on a default installation, but I'd like to work towards that for 11.04.
