When I attempt to add or remove any package, I get an error message from apt-get:
The following packages have unmet dependencies: ubuntu-desktop : Depends: nvidia-common but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Trying apt-get -f install:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
nvidia-common
The following NEW packages will be installed:
nvidia-common
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
1 not fully installed or removed.
Need to get 0 B/19.0 kB of archives.
After this operation, 155 kB of additional disk space will be used.
Do you want to continue [Y/n]?
Preconfiguring packages ...
(Reading database ... 430130 files and directories currently installed.)
Unpacking nvidia-common (from .../nvidia-common_1%3a0.2.44.2_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/nvidia-common_1%3a0.2.44.2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/nvidia/pre-install', which is also in package nvidia-installer-cleanup 20131102+1~bpo70+1
Exit 100
Apparently two packages, nvidia-common and nvidia-installer-cleanup, share the same file, pre-install, which prevents nvidia-common from being installed, which prevents anything else from being installed. The truth is, I use a proprietary Radeon driver and do not even need NVidia.
P.S. The output of dpkg -l | grep glx:
ii glx-alternative-fglrx 0.4.1~bpo70+1 allows the selection of FGLRX as GLX provider ii glx-alternative-mesa 0.4.1~bpo70+1 allows the selection of MESA as GLX provider ii glx-diversions 0.4.1~bpo70+1 prepare for using accelerated GLX implementations from GPU vendors ii libgl1-mesa-glx 8.0.4-0ubuntu0.7 free implementation of the OpenGL API -- GLX runtime ii libgl1-mesa-glx:i386 8.0.4-0ubuntu0.7 free implementation of the OpenGL API -- GLX runtime rc libglitz-glx1 0.5.6-1build1 Glitz OpenGL library GLX backend ii libswt-glx-gtk-3-jni 3.7.2-2 Standard Widget Toolkit for GTK+ GLX JNI library ii libxcb-glx0 1.8.1-1ubuntu0.2 X C Binding, glx extension ii libxcb-glx0:i386 1.8.1-1ubuntu0.2 X C Binding, glx extension
The output of apt-cache rdepends nvidia-common:
nvidia-common Reverse Depends: jockey-common nvidia-common:i386 ubuntu-desktop jockey-common nvidia-common:i386 xubuntu-desktop ubuntustudio-desktop nvclock-qt nvclock-gtk nvclock mythbuntu-common lubuntu-core ubuntu-desktop kubuntu-desktop jockey-common
The output of apt-cache policy nvidia-common nvidia-installer-cleanup:
nvidia-common:
Installed: (none)
Candidate: 1:0.2.44.2
Version table:
1:0.2.44.2 0
500 http://us.archive.ubuntu.com/ubuntu/ precise-updates/main amd64 Packages
1:0.2.44 0
500 http://us.archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
Installed: 20131102+1~bpo70+1
Candidate: 20131102+1~bpo70+1
Version table:
*** 20131102+1~bpo70+1 0
100 http://http.debian.net/debian/ wheezy-backports/contrib amd64 Packages
100 /var/lib/dpkg/status
