Im trying to install Django.
When I use sudo apt-get install pip, there is an error pip not found.
I used sudo easy_install pip, there is an error command easy_install not found.
I used sudo apt-get install python-virtualenv, even that is not working.
jobin
  • 28,567
You can install pip using:
sudo apt-get install python-pip
django using
sudo apt-get install python-django
Tip to know the correct package name to install:
If you know what the package you are trying to install does, you can search its exact name using apt-cache search as follows:
apt-cache search pip | grep install
I grep it with install since I know pip is used to install python libraries, so "install" might be in the summary for pip.
jobin
  • 28,567
I think that the best workflow would be:
  • Install easy_install:
sudo apt-get install python-setuptools
  • Install latest version of pip with easy_install:
  • Once pip installed install django:
sudo pip install django
Having said this, I would recommend you install django via venv since it's not a good practice install it system wide.
xoner
  • 126
