I just did a fresh install of Ubuntu 14.04 64-bit, and it seems that most major packages I attempt to install (among them being Skype, Steam/Steam-Launcher, WINE, etc.), give an "unmet dependencies" error and refuse to install.
I have looked at several other questions of a similar description (many duplicates) but none of the solutions worked and I have not yet found someone with this specific issue.
Installing Skype:
stere0123@stere0123-THINKPAD-U14:~$ sudo apt-get install skype
Reading package lists... Done
Building dependency tree
 skype : Depends: skype-bin
I get similar errors with some other packages I've tried as well. Any help would be greatly appreciated as this problem is currently crippling this system!
change download server as suggested above:
Open your source.list using your favorite text editor, ie
sudo nano /etc/apt/sources.list locate http://us.archive.ubuntu.com/ubuntu and replace it with http://archive.ubuntu.com/ubuntu
sudo apt-get -f install
It will solve you'r problem.
see this question and thia there are lot of question on this topic.
smali
  • 584
  • 17
