If I apt-get install tomcat7 it is installing a broken tomcat7. A simple startup.sh will give me errors, than when fixed says that tomcat has started but nothing shows up in localhost:8080. shutdown.sh will give me errors and even throw Java exceptions.
This wasn't happening in some previous Ubuntu release, where it simply worked. So, it is looks like tomcat package it been not maintained lately.
I can get it working from Eclipse (which by the way it is not been properly maintain too) when I am testing my web app. However there are things I need to test in an standalone tomcat installation. So far, Google hasn't helped.
Have any of you managed to properly installing tomcat7 in Ubuntu 14.4LTS? If so, can you point me to the right direction?
Edit:
Here is some logs.
Starting tomcat:
$ sudo /usr/share/tomcat7/bin/startup.sh
Using CATALINA_BASE: /usr/share/tomcat7
Using CATALINA_HOME: /usr/share/tomcat7
Using CATALINA_TMPDIR: /usr/share/tomcat7/temp
Using JRE_HOME: /usr
Using CLASSPATH: /usr/share/tomcat7/bin/bootstrap.jar:/usr/share/tomcat7/bin/tomcat-juli.jar
Tomcat started.
Browsing to localhost:8080 (and http://127.0.0.1:8080, http://127.0.0.1, http://[my network ip here]):
Oops! Google Chrome could not connect to localhost:8080
Stopping tomcat also fails:
$ sudo /usr/share/tomcat7/bin/shutdown.sh
Jul 03, 2014 7:15:55 PM org.apache.catalina.startup.ClassLoaderFactory validateFile
WARNING: Problem with directory [/usr/share/tomcat7/common/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/common], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/server/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/server], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/shared/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/shared], exists: [false], isDirectory: [false], canRead: [false]
Jul 03, 2014 7:15:55 PM org.apache.catalina.startup.Catalina stopServer
SEVERE: Catalina.stop:
java.io.FileNotFoundException: /usr/share/tomcat7/conf/server.xml (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:146)
at org.apache.catalina.startup.Catalina.stopServer(Catalina.java:466)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.apache.catalina.startup.Bootstrap.stopServer(Bootstrap.java:370)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:457)
