13
From time to time, we may have to install something from source due to various reasons. While it is fairly standard how to install software given appropriate dependencies, it is not clear to me how to manage such installation for future convenience.
More specifically:
  1. What can we do to ensure an easy and clean uninstallation (including those dependencies that are installed just before and just for the software installed from source)?
  2. What can we do to ensure an easy and clean upgrade of the same software, which will likely be installed from source again?
  3. What can we do to minimize potential conflict if there are a default package (installed using apt-get) as well as the (newer) version of the package (installed from source)?
Seth
  • 59,332
skyork
  • 441
Using checkinstall make install will create a temporary package and install it. This means it is recorded in the package manager and can be uninstalled.
user54114
  • 181
The best thing to do would be to make Debian packages of the newer versions yourself. dpkg and the apt tools do all three things that you mention and are intended for that purpose. Use them instead of reinventing the wheel. There are plenty of guides on packaging available. If the software already exists in the repositories, you can probably get the source package (apt-get src) which you can use to study and kick start your own package.
This answer to https://askubuntu.com/a/485230/158442 might be useful as a general guideline.
While checkinstall is great for a quick and dirty solution, long term you should use proper packaging.
muru
  • 207,228
First of all, much depends upon how you manage your source codes. I make a directory like ~/sources and put every program in it's subdirectories, while others will create a new directory for every program.
Similarly some like me, create a new sub-sub-directory for every new version, and remove older versions only when it's ensured that there are no significant bugs in new version that would stop my work.
There is no single way to do this, but whichever way you choose, choose a way that would be easiest for you to manage.
  1. Clean Uninstallation
    • I would suggest creating a rem_dep.sh script which would look like this.
      #! /bin/bash
      sudo apt-get remove dep1 dep2 ... depn
      where dep1, dep2, depn are dependencies.
  2. Clean & easy upgrade
    • if you get source code from a automated versioning system like git or bazaar or if the links are predictable you can create a shell script which will
      #1 make a backup of earlier version
      #2 get new source
      #3 configure, build/make the source
      #5 if make went correctly, remove earlier version.
      #6 make install new version, update dependencies if required.
    • In other cases too, you can create such scripts with manual work to some extent.
  3. Conflict management
    • The best way is to use the --prefix option while install softwares and there dependencies.
    • Other important thing is to keep your system updated so as to minimize conflicts.
NOTE: If you find yourself compiling more software than you should(set a max_limit for yourself, like 5 or 10 or 100) it's best you leave Ubuntu and move to Arch Linux.
Build dependencies:
  • AFAIK they should be recorded manually. You can create a file like README to keep list of manually installed dependencies.
  • If that software has already a built binary in Ubuntu or PPA repositories. Tracking dependencies while installation should easier:
    sudo apt-get build-dep target_package
Clean uninstall:
Keep the configured&installed source folder. Better if you collect all sources in specific folder with the file of installed dependencies.
Clean upgrade & installed files isolation:
Install them in specific --prefix (preferably --prefix=/opt/software_name-version/).
This will solve many problems: concurrent versions with the one from repository; clean upgrade; easier for dirty uninstall in case source was deleted.
More sophisticate or the best way, as @muru answer, Build a Debian package (For packages available in Ubuntu/PPA repositories)
user.dz
  • 49,176
