I was trying to get my cd mounted (that problem got fixed), but I burned something to my cd as a test and now I can't get it off.
Asked
Active
Viewed 5,102 times
If it is an CD-R, you just can't.
If it's an CD-RW you need to delete the disc before adding new content. Delete a folder on CD is nothing I'm aware of it's possible at all. If you need so, you should make a backup of your CD and complete reburn it.
frlan
- 1,050
- 5
- 17
If it's a DVD-RW, you need to format the DVD.
If it's a DVD-+R, usually you can't. However, if your DVD-R writing software used packet writing and a compatible filesytem (e.g. UDF), then it might be possible to make the already written files invisible. Sometimes this is also referred to as writing "sessions". Here is how to write such a DVD in Brasero.
