There is no real configuration file.
Unity and Compiz are using GConf to store their settings. GConf is a
configuration store that provides an API for applications to read and
write configuration information and receive notifications when
configuration items change. The configuration data is saved under
~/.gconf, but modifications should only be made through the GConf
daemon.
You can modify the Unity settings directly using gconf-editor and
browsing to /apps/compiz-1/plugins/unityshell/screen0/options. You
will notice that Unity responds to changes instantly, the same as
CCSM.
If you want a command line tool to modify these settings, use
gconftool-2. For example, to reduce the launcher icon size I can
do:
gconftool-2 --set /apps/compiz-1/plugins/unityshell/screen0/options/icon_size --type int 32
The GConf file seems as it shouldn't be messed with.
A better alternative would be either a.) resetting that specific page with the button if something goes wrong or b.) taking a screenshot. As far as the sliders, IIRC they should have a tooltip attached, although I'm not positive.
You really shouldn't be worried about corrupting something, but if you do (very unlikely), it shouldn't be that hard to reset Unity.
