when i tried to install ubuntu from bootable USB it couldn't recognize my installed windows 7 so it showed me like i have to erase my whole drive and then ubuntu can be installed. please help me with this ASAP.
Asked
Active
Viewed 2,164 times
Ok, This should not be a problem.
First try with wubi which comes with Ubuntu 1404 LTS CD. Inside there wubi icon can be found. Once you double click it, it will starts the installation as a normal windows program. But what this does is that it installs the Ubuntu on the system as a dual boot instead as a program inside the windows. Thats all..
When system rebooting it will give you list of OS to select.
krs4keshara
- 159
In the Ubuntu terminal, execute the command line below:
sudo update-grub
Then reboot the system, then you could see the boot menu options including both windows7 and ubuntu.
Please refer to:
Problems installing and dual booting Ubuntu 12.4, 13.10, and 14.4.1 via pendrivelinux?
