I started installing phpmyadmin via SSH on an Ubuntu server and got to a question I couldn't answer and had to close. How do I resume the installation or stop it and start over?
The command sudo apt-get install phpmyadmin gives the error:
could not get lock [path] - open
unable to lock the administration directory
The command ps aux | grep apt gives 4 processes including apt-get install phpmyadmin.
BTW, the question I had was whether I should use dbconfig-common when I have existing databases. The explanation was confusing.
user.dz
  • 49,176
NathanB
  • 23
I've never used SSH to connect to servers, but if I were having this problem on a local machine I would reboot to get rid of the lock problem, and then type "sudo apt-get install --reinstall phpmyadmin"
It would be better if you restarted your ubuntu server to release the lock and then, try to reinstall phpmyadmin.
As a last resource you can delete the lock file, this is discussed here: Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?
