I have a 320 Gigs HDD with no partition and Ubuntu installed on it, but I can't see the display when it enters lock screen or the desktop. I tried running Ubuntu through a live USB Flash drive and it worked perfectly. I must've done something at the terminal that the display goes off.
Anyways, now I'm thinking to copy my data to an external HDD and re-install Ubuntu. But when I try to copy any folder to external HDD it says "The folder 'folder name' cannot be handled because you do not have permissions to read it".Or when I open a folder it says "You don't have permissions necessary to view the contents of 'folder name'". How can I get permissions to do so and copy the files to an external HDD, and re-install Ubuntu.
(The file system of the internal HDD is ext4 if that matters)
Help me please!
Billa
  • 33
You can get around this by running your file manager with root priviledges. In your terminal type "sudo nautilus". You should now be able to access the folders and files so you can copy them.
