When trying to install Ubuntu I selected the default checked "Erase hardrive" option and checked the second box below it (below an option to encrypt which I didn't select) which had to do with installing tools to make partitioning easier. There was a small warning in red text around the Erase hard drive option that said it would delete all my files, but I clicked Continue anyway because I assumed I'd be given an option to Revert or some kind of warning if this really would mess up my system. Instead though, it sent me to the Choose Your Location screen within the applet and the back button became grayed and unusable, which is when I worried that it may have messed up my partitions. (It technically has no valid OS I can boot from now...)
I exited the installer then and shut down, and upon trying to boot into windows I simply had a black screen with a "_" sign at the top left hand corner phasing in and out, without any ability to access windows, or any other OS because I actually didn't install Linux but just let the applet reconfigure the partitions.
My first question to all of you out there is A, Is there any simple way I can get my partition structure back and boot into windows, especially seeing how it was so easy to revert modified partitions within the Ubuntu applet, and HOW?!
I've installed Ubuntu-Rescue-Remix onto a usb and am messing with it using TestDisk and their guide but it either doesn't seem to be working or I have no idea what I'm doing. There doesn't seem to be much in the way of clear answers about how to undo something which is as simple as a messed up file structure, so if this isn't the best way, anyone who knows better please give a shout out or advice!
Worst case I guess I'll just fully install Ubuntu on the computer and try to salvage the files onto an external hard drive and reinstall Windows. Either this or take it to a specialist. It just seems stupid that a simple Continue button being clicked/tapped is the difference between the user moving on to something else or being hit with something they have to go through immense trouble to fix.
- update, this guy had the same problem: Windows 7 to Ubuntu - erased data / but additional suggestions or links to step by steps appreciated
- does boot-repair work for this? ..........
My second question, B, is a request: Is there any way the Ubuntu Install Applets' developers would consider adding warning features like bright flashing lights or a Warning Popup to tell you that hard drive erasure is not easily reversible if you press Continue from within the applet, like how Windows and other OS security and system popups often do when they're warning that you might be about to do something stupid? Or advice that we need to either destroy a partition structure and risk data loss or resize the partition safely on our main operating system in order to install Ubuntu safely?
If I'd been told by the Applet clearly that I had no options to install Linux without messing with partitions and risking data loss, I would have just taken it to a computer specialist about the Windows computer going slow or freezing after login instead of having to play specialist or hire one to salvage my data. I'm sure I'm not the only one who's had this problem, and it seems like a simple fix like this could save people a lot of frustration and heartache, both in Ubuntu from Canonical and forks from the Mint and Kubuntu projects.
Please Ubuntu developers, help the 'visual-learners' and novice-tinkerers who need to be given flashing warning signs in order to not destroy their computers!!! Do it for the Children!!! Do it for the Exclamation Points!!! Do it for Me, so I don't feel as bad about this mistake being repeated again despite this bad experience with it!!!!! Please/ Just/ Do It!!!!!!!!!!!
