Since I installed Ubuntu I was unable to install video Codecs I get the following errors: The following packages have unmet dependencies:
    gstreamer1.0-libav: Depends: libavcodec-extra-54 (>= 6:9.13) but 7:1.2.5-1~trusty1 is to be installed
                        Depends: libavformat54 (>= 6:9.1-1) but 7:1.2.5-1~trusty1 is to be installed
                        Depends: libavutil52 (>= 6:9.1-1) but 7:1.2.5-1~trusty1 is to be installed
                        Depends: libc6 (>= 2.14) but 2.19-0ubuntu6 is to be installed
                        Depends: libglib2.0-0 (>= 2.37.3) but 2.40.0-2 is to be installed
    gstreamer1.0-libav:i386: Depends: libavcodec-extra-54 (>= 6:9.13) but 7:1.2.5-1~trusty1 is to be installed
                             Depends: libc6 (>= 2.7) but 2.19-0ubuntu6 is to be installed
However, I was using VLC. I had to uninstall VLC for a reason, now I'm unable to reinstall it. When I try to install VLC it gives me the following errors:
 vlc : Depends: vlc-nox (= 2.1.4-0ubuntu14.04.1) but it is not going to be installed
       Recommends: vlc-plugin-notify (= 2.1.4-0ubuntu14.04.1) but it is not going to be installed
       Recommends: vlc-plugin-pulse (= 2.1.4-0ubuntu14.04.1) but it is not going to be installed
I've tried all the solve for this kind of problems, none of the worked for me. I've also tried aptitude which also didn't worked. Installation from source also failed.
apt-get update gives me an error:
W: GPG error: http://ppa.launchpad.net trusty Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 6A9653F936FD5529
Braiam
  • 69,112
ashik992
  • 171
The problem was the error with the signature. The solve was the following commands:
gpg --keyserver keyserver.ubuntu.com --recv 6A9653F936FD5529
gpg --export --armor 6A9653F936FD5529 | sudo apt-key add -
ashik992
  • 171
