I have this adapter and I'm trying desperately to mount it in Ubuntu so I can use can-utils to monitor the device but I'm failing.
I'm trying to communicate with a serial to the can-bus adapter in 14.04 with can-utils this is the canopen device I'm trying to get at and this is the adapter I'm using
dmesg:
[ 4316.555254] usb 3-3: new full-speed USB device number 8 using xhci_hcd
[ 4316.572534] usb 3-3: New USB device found, idVendor=1a86, idProduct=7523
[ 4316.572541] usb 3-3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4316.572545] usb 3-3: Product: USB2.0-Serial
[ 4316.573058] ch341 3-3:1.0: ch341-uart converter detected
[ 4316.574083] usb 3-3: ch341-uart converter now attached to ttyUSB1
[ 4836.845113] CAN device driver interface
[ 5389.346203] can: broadcast manager protocol (rev 20120528 t)
[ 5570.910652] systemd-hostnamed[23407]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
That is dmesg output for the device
Which I think is the device.
lsusb gives me:
Bus 003 Device 002: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
I've managed to mount it to slcan0 like so:
sudo slcand -o -s6 -t hw -S 3000000 /dev/ttyUSB2
ip link set up slcan0
IP link then gives me:
6: slcan1: <NOARP,UP,LOWER_UP> mtu 16 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 10
link/can
No matter what I then throw it via can-send I can't get a response back...
