Sorry about the name, I have no idea how to describe this in a short phrase. So I had windows crash and it wouldn't boot from the disk, it is a 500gb hitachi 5200rpm drive on an acer aspire 7560. I booted from my linux hard drive, used the "disks" or whatever program, and it said that I had 1000 or so "bad blocks" I checked an hour later and it said it had "3800" bad blocks, I am running badblocks on it right now with the non-destructive read/write test and it shows only read errors, no write or compare errors. Does this mean that there are only data corruption errors on the disk from an abrupt shutdown, or is the disk surface genuinely damaged? The number of bad blocks has not increased since I checked two hours ago, in fact it seems to have decreased from what I recall. EDIT: I got some compare errors, actually, here is a log of what it has given me so far:
sawyer@sawyer-Vostro-1720:/home-ext/home/sawyer$ sudo badblocks -v -n -s /dev/sdb
[sudo] password for sawyer:
Checking for bad blocks in non-destructive read-write mode
From block 0 to 488386583
Checking for bad blocks (non-destructive read-write test)
Testing with random pattern: 0.00% done, 0:37 elapsed. (0/0/0 errors)
217784% done, 19:14 elapsed. (0/0/0 errors)
217785% done, 19:20 elapsed. (1/0/0 errors)
217786% done, 19:27 elapsed. (2/0/0 errors)
217787% done, 19:33 elapsed. (3/0/0 errors)
217792% done, 19:49 elapsed. (4/0/0 errors)
217793% done, 19:56 elapsed. (5/0/0 errors)
217794% done, 20:02 elapsed. (6/0/0 errors)
217795% done, 20:09 elapsed. (7/0/0 errors)
217800% done, 20:15 elapsed. (8/0/0 errors)
217801% done, 20:22 elapsed. (9/0/0 errors)
217802% done, 20:28 elapsed. (10/0/0 errors)
217803% done, 20:38 elapsed. (11/0/0 errors)
217816% done, 20:44 elapsed. (12/0/0 errors)
217817% done, 20:51 elapsed. (13/0/0 errors)
217818% done, 21:00 elapsed. (14/0/0 errors)
217819% done, 21:07 elapsed. (15/0/0 errors)
217828% done, 21:14 elapsed. (16/0/0 errors)
217829% done, 21:23 elapsed. (17/0/0 errors)
217830% done, 21:30 elapsed. (18/0/0 errors)
217831% done, 21:36 elapsed. (19/0/0 errors)
217832% done, 21:43 elapsed. (20/0/0 errors)
217833% done, 21:49 elapsed. (21/0/0 errors)
217834% done, 21:56 elapsed. (22/0/0 errors)
217835% done, 22:02 elapsed. (23/0/0 errors)
217836% done, 22:09 elapsed. (24/0/0 errors)
217837% done, 22:15 elapsed. (25/0/0 errors)
217838% done, 22:22 elapsed. (26/0/0 errors)
217839% done, 22:29 elapsed. (27/0/0 errors)
217840% done, 22:35 elapsed. (28/0/0 errors)
217841% done, 22:42 elapsed. (29/0/0 errors)
217842% done, 22:48 elapsed. (30/0/0 errors)
217843% done, 22:55 elapsed. (31/0/0 errors)
217844% done, 23:01 elapsed. (32/0/0 errors)
217845% done, 23:08 elapsed. (33/0/0 errors)
217846% done, 23:14 elapsed. (34/0/0 errors)
217847% done, 23:21 elapsed. (35/0/0 errors)
217848% done, 23:30 elapsed. (36/0/0 errors)
217856% done, 24:02 elapsed. (37/0/0 errors)
217857% done, 24:09 elapsed. (38/0/0 errors)
217864% done, 24:20 elapsed. (39/0/0 errors)
217865% done, 24:27 elapsed. (40/0/0 errors)
217866% done, 24:33 elapsed. (41/0/0 errors)
217867% done, 24:40 elapsed. (42/0/0 errors)
217868% done, 24:46 elapsed. (43/0/0 errors)
217869% done, 24:52 elapsed. (44/0/0 errors)
217870% done, 24:59 elapsed. (45/0/0 errors)
217871% done, 25:05 elapsed. (46/0/0 errors)
217876% done, 25:18 elapsed. (47/0/0 errors)
217877% done, 25:24 elapsed. (48/0/0 errors)
217878% done, 25:31 elapsed. (49/0/0 errors)
217879% done, 25:37 elapsed. (50/0/0 errors)
217908% done, 25:57 elapsed. (51/0/0 errors)
217909% done, 26:06 elapsed. (52/0/0 errors)
217912% done, 26:19 elapsed. (53/0/0 errors)
217916% done, 26:29 elapsed. (54/0/0 errors)
217917% done, 26:32 elapsed. (55/0/0 errors)
217918% done, 26:45 elapsed. (56/0/0 errors)
217919% done, 26:51 elapsed. (57/0/0 errors)
218040% done, 27:57 elapsed. (58/0/0 errors)
218041% done, 28:01 elapsed. (59/0/0 errors)
218049% done, 28:42 elapsed. (60/0/0 errors)
218052% done, 28:55 elapsed. (61/0/0 errors)
218053% done, 28:59 elapsed. (62/0/0 errors)
218054% done, 29:12 elapsed. (63/0/0 errors)
218055% done, 29:21 elapsed. (64/0/0 errors)
218056% done, 29:25 elapsed. (65/0/0 errors)
218057% done, 29:31 elapsed. (66/0/0 errors)
218080% done, 30:22 elapsed. (67/0/0 errors)
218084% done, 30:39 elapsed. (68/0/0 errors)
218085% done, 30:52 elapsed. (69/0/0 errors)
218086% done, 30:56 elapsed. (70/0/0 errors)
218113% done, 31:19 elapsed. (71/0/0 errors)
218148% done, 31:29 elapsed. (72/0/0 errors)
218149% done, 31:37 elapsed. (73/0/0 errors)
218150% done, 31:47 elapsed. (74/0/0 errors)
218151
218152
218153% done, 32:06 elapsed. (75/0/2 errors)
218155% done, 32:16 elapsed. (76/0/2 errors)
218156
218157% done, 32:36 elapsed. (77/0/3 errors)
218160% done, 32:52 elapsed. (78/0/3 errors)
218164
218165% done, 33:15 elapsed. (79/0/4 errors)
218166% done, 33:27 elapsed. (80/0/4 errors)
218167% done, 33:40 elapsed. (81/0/4 errors)
218168% done, 33:53 elapsed. (82/0/4 errors)
218169% done, 34:00 elapsed. (83/0/4 errors)
218170% done, 34:10 elapsed. (84/0/4 errors)
218171% done, 34:16 elapsed. (85/0/4 errors)
218172% done, 34:23 elapsed. (86/0/4 errors)
218173% done, 34:39 elapsed. (87/0/4 errors)
218174% done, 34:45 elapsed. (88/0/4 errors)
218175% done, 34:52 elapsed. (89/0/4 errors)
218244% done, 35:06 elapsed. (90/0/4 errors)
218245% done, 35:09 elapsed. (91/0/4 errors)
218246% done, 35:16 elapsed. (92/0/4 errors)
218247% done, 35:22 elapsed. (93/0/4 errors)
218248% done, 35:25 elapsed. (94/0/4 errors)
218249% done, 35:29 elapsed. (95/0/4 errors)
218250% done, 35:32 elapsed. (96/0/4 errors)
218251% done, 35:35 elapsed. (97/0/4 errors)
218252% done, 35:42 elapsed. (98/0/4 errors)
218253% done, 35:48 elapsed. (99/0/4 errors)
218254% done, 35:54 elapsed. (100/0/4 errors)
218255% done, 36:01 elapsed. (101/0/4 errors)
218256% done, 36:07 elapsed. (102/0/4 errors)
218257% done, 36:14 elapsed. (103/0/4 errors)
218258% done, 36:20 elapsed. (104/0/4 errors)
218259% done, 36:27 elapsed. (105/0/4 errors)
218260% done, 36:33 elapsed. (106/0/4 errors)
218261% done, 36:40 elapsed. (107/0/4 errors)
218262% done, 36:46 elapsed. (108/0/4 errors)
218263% done, 36:53 elapsed. (109/0/4 errors)
218264% done, 36:59 elapsed. (110/0/4 errors)
218265% done, 37:06 elapsed. (111/0/4 errors)
218266% done, 37:09 elapsed. (112/0/4 errors)
218267% done, 37:15 elapsed. (113/0/4 errors)
218268% done, 37:22 elapsed. (114/0/4 errors)
218269% done, 37:28 elapsed. (115/0/4 errors)
218270% done, 37:35 elapsed. (116/0/4 errors)
218271% done, 37:41 elapsed. (117/0/4 errors)
218272% done, 37:48 elapsed. (118/0/4 errors)
218273% done, 37:57 elapsed. (119/0/4 errors)
218274% done, 38:01 elapsed. (120/0/4 errors)
218275% done, 38:07 elapsed. (121/0/4 errors)
218276% done, 38:14 elapsed. (122/0/4 errors)
218277% done, 38:20 elapsed. (123/0/4 errors)
218278% done, 38:26 elapsed. (124/0/4 errors)
218279% done, 38:33 elapsed. (125/0/4 errors)
218280% done, 38:39 elapsed. (126/0/4 errors)
218281% done, 38:46 elapsed. (127/0/4 errors)
218282% done, 38:56 elapsed. (128/0/4 errors)
218283% done, 39:03 elapsed. (129/0/4 errors)
218284% done, 39:09 elapsed. (130/0/4 errors)
218285% done, 39:16 elapsed. (131/0/4 errors)
218286% done, 39:22 elapsed. (132/0/4 errors)
218287% done, 39:28 elapsed. (133/0/4 errors)
218288% done, 39:35 elapsed. (134/0/4 errors)
218289% done, 39:41 elapsed. (135/0/4 errors)
218290% done, 39:48 elapsed. (136/0/4 errors)
218291% done, 39:58 elapsed. (137/0/4 errors)
218292% done, 40:04 elapsed. (138/0/4 errors)
218293% done, 40:11 elapsed. (139/0/4 errors)
218294% done, 40:14 elapsed. (140/0/4 errors)
218295% done, 40:20 elapsed. (141/0/4 errors)
218296% done, 40:27 elapsed. (142/0/4 errors)
218297% done, 40:33 elapsed. (143/0/4 errors)
218298% done, 40:40 elapsed. (144/0/4 errors)
218299% done, 40:43 elapsed. (145/0/4 errors)
218300% done, 40:49 elapsed. (146/0/4 errors)
218301% done, 40:59 elapsed. (147/0/4 errors)
218302% done, 41:05 elapsed. (148/0/4 errors)
218303% done, 41:12 elapsed. (149/0/4 errors)
218304% done, 41:15 elapsed. (150/0/4 errors)
218434% done, 43:37 elapsed. (151/0/4 errors)
218436% done, 43:47 elapsed. (152/0/4 errors)
218437% done, 44:00 elapsed. (153/0/4 errors)
218438% done, 44:13 elapsed. (154/0/4 errors)
218439% done, 44:26 elapsed. (155/0/4 errors)
I know it is disorganized, but the count of currently pending sectors is what I was talking about, not the reallocation or reallocated sector counts
0.05% done, 1:39:16 elapsed. (444/0/124 errors)
is the latest output
