I try to load the dictionary es-ES.dic in the folder usr\share\myspell\dicts (needed for TEXMAKER) but I am not permited because I am not "owner" How can I solve this?
Use command:
First change directory to the folder where the "es-ES.dic" is by using:
$ cd /path
Then copy using:
$ sudo cp -R es-ES.dic /usr/share/myspell/dicts
Raphael
  • 8,135
You need to open nautilus as root, then open the file:
sudo nautilus /usr/share/myspell/dicts
Or open the file directly:
sudo xdg-open /usr/share/myspell/dicts/es-ES.dicbegining
Also, a note. In Ubuntu, file locations use / instead of \ like in windows, and we always put a / at the beginning, like the equivalent of C:\. So your location should not be written as:
usr/share/myspell/dicts/ or even usr\share\myspell\dicts
But as this:
Tim
  • 33,500
