- host: IBM x3850
- FC-HBA: qlogic qle2562, dualport
- DAS-storage: IBM DS3500 dual-controller, 1 port per controller connected
After setting up a new install of 14.04 and configuring devices, I get device errors during boot for every device and every port of DS3500: see log below.
I tried to change host operating system in DS3500 from MPP/RDAC to LNXALUA. The error messages went away but mutlipath -ll shows that RDAC is used. After adjusting multipath.conf to use ALUA getting error:
multipathd: A dynamic linking error occurred: /lib/multipath/libcheckalua.so: cannot open >shared object file: No such file or directory)
could not resolve ….
Back on MPP/RDAC multipath -ll shows nothing and syslog shows errors like below logs on bottom. Multipath does not work by now ...
Any advise would be appreciated!
Logs:
15.331957] qla2xxx [0000:86:00.0]-00fb:3: QLogic QLE2562 - QLogic 8Gb FC Dual-port HBA for System x.
15.372195] qla2xxx [0000:86:00.0]-00fc:3: ISP2532: PCIe (5.0GT/s x8) @ 0000:86:00.0 hdma+ host#=3 fw=7.01.00 (90d5).
15.414007] qla2xxx [0000:86:00.1]-001d: : Found an ISP2532 irq 64 iobase 0xffffc90072cd0000.
15.456150] qla2xxx 0000:86:00.1: irq 113 for MSI/MSI-X
15.456181] qla2xxx 0000:86:00.1: irq 114 for MSI/MSI-X
17.665675] qla2xxx [0000:86:00.0]-505f:3: Link is operational (8 Gbps).
18.030629] qla2xxx [0000:86:00.0]-1020:3: **** Failed mbx[0]=4006, mb[1]=7fe, mb[2]=1, mb[3]=4, cmd=6a ****.
18.072622] scsi 3:0:0:0: Direct-Access IBM Universal Xport 1070 PQ: 0 ANSI: 5
18.117509] scsi 3:0:0:1: Direct-Access IBM 1746 FAStT 1070 PQ: 0 ANSI: 5
18.160602] scsi 3:0:0:0: Attached scsi generic sg2 type 0
18.204151] sd 3:0:0:1: Attached scsi generic sg3 type 0
18.205012] sd 3:0:0:1: [sdb] 1048576000 512-byte logical blocks: (536 GB/500 GiB)
18.206125] sd 3:0:0:1: [sdb] Write Protect is off
18.206128] sd 3:0:0:1: [sdb] Mode Sense: 83 00 10 08
18.206498] sd 3:0:0:1: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
18.338163] scsi4 : qla2xxx
18.347073] qla2xxx [0000:86:00.1]-00fb:4: QLogic QLE2562 - QLogic 8Gb FC Dual-port HBA for System x.
18.347078] qla2xxx [0000:86:00.1]-00fc:4: ISP2532: PCIe (5.0GT/s x8) @ 0000:86:00.1 hdma+ host#=4 fw=7.01.00 (90d5).
18.347571] qla2xxx [0000:95:00.0]-001d: : Found an ISP2532 irq 56 iobase 0xffffc90072cde000.
18.348125] qla2xxx 0000:95:00.0: irq 115 for MSI/MSI-X
18.348141] qla2xxx 0000:95:00.0: irq 116 for MSI/MSI-X
18.713762] sd 3:0:0:1: [sdb]
18.758261] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
18.802896] sd 3:0:0:1: [sdb]
18.845334] Sense Key : Illegal Request [current]
18.888324] sd 3:0:0:1: [sdb]
18.927702] <<vendor>> ASC=0x94 ASCQ=0x1ASC=0x94 ASCQ=0x1
18.969035] sd 3:0:0:1: [sdb] CDB:
19.009541] Read(10): 28 00 00 00 00 00 00 00 08 00
19.050279] end_request: I/O error, dev sdb, sector 0
19.089456] Buffer I/O error on device sdb, logical block 0
19.630029] sd 3:0:0:1: [sdb]
19.666857] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
64.504856] sd 3:0:0:1: rdac: LUN 1 (RDAC) (unowned)
64.505737] sd 5:0:0:1: rdac: LUN 1 (RDAC) (owned)
64.505742] rdac: device handler registered
64.548834] device-mapper: multipath round-robin: version 1.0.0 loaded
64.555789] device-mapper: table: 252:0: multipath: error getting device
64.556196] sd 3:0:0:1: [sdb]
64.556198] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
64.556200] sd 3:0:0:1: [sdb]
64.556202] Sense Key : Illegal Request [current]
64.556203] sd 3:0:0:1: [sdb]
64.556211] <<vendor>> ASC=0x94 ASCQ=0x1ASC=0x94 ASCQ=0x1
64.556213] sd 3:0:0:1: [sdb] CDB:
64.556217] Read(10): 28 00 3e 7f ff f0 00 00 08 00
64.556219] end_request: I/O error, dev sdb, sector 1048575984
64.556221] Buffer I/O error on device sdb, logical block 131071998
64.740877] device-mapper: ioctl: error adding target to table
64.751583] device-mapper: table: 252:0: multipath: error getting device
64.811318] device-mapper: ioctl: error adding target to table
64.836536] device-mapper: table: 252:0: multipath: error getting device
64.898305] device-mapper: ioctl: error adding target to table
64.910448] device-mapper: table: 252:0: multipath: error getting device
64.968345] device-mapper: ioctl: error adding target to table
64.985344] device-mapper: table: 252:0: multipath: error getting device
65.045745] device-mapper: ioctl: error adding target to table
65.065624] device-mapper: table: 252:0: multipath: error getting device
65.121701] device-mapper: ioctl: error adding target to table
65.145184] device-mapper: table: 252:0: multipath: error getting device
65.202583] device-mapper: ioctl: error adding target to table
65.223581] device-mapper: table: 252:0: multipath: error getting device
65.281298] device-mapper: ioctl: error adding target to table
65.295510] device-mapper: table: 252:0: multipath: error getting device
65.354897] device-mapper: ioctl: error adding target to table
65.372987] device-mapper: table: 252:0: multipath: error getting device
65.427124] device-mapper: ioctl: error adding target to table
