I think the answer maybe Mtools.
Mtools allow you to access MS-DOS formatted floppy disks without having to mount them in Linux.
If these tools are not already installed in your system then you can install them using your package manager.
So, the first step is to see if you already have the mtools package installed. From a terminal type: mtools and press enter.
If mtools is installed, you should see a list of commands all starting with the letter m. If you get an error then you will need to install the package.
In Debian based systems you can install mtools by typing:
#apt-get install mtools and then enter your password.
In RPM based distributions you can type:
#yum install mtools and then enter.
Note: In the above commands, # signifies the root user. You can either log in as root or use the sudo command in Ubuntu and the su -c 'command' in other distros.
Now insert one of your floppy disks that you want to access.
Note: You will need to use a terminal from this point forward.
Now depending on your system, begin the commands with either sudo or su -c ', as you need root privileges to use mtools.
For example, to view the contents of the floppy disk, use the mdir command by typing:
sudo mdir a: then press enter. You should now hear the floppy drive read the disk and show the contents.
If you have any directories there, you can access them by using the mcd command.
(mcd basically does the same as the cd command in Linux. It changes the current directory to a different one. )
EG: mcd a:/pictures
If you want to copy files from the floppy to your home directory you can do so by using the mcopy command.
Here are some examples:
Copy one file to the photos directory in your home folder. mcopy a:/photo22 /home/user/photos/
Copy all files on the root directory of the floppy drive to the photos directory. mcopy a:/* /home/user/photos/
Copy the pictures directory from the floppy drive to your home folder. mcopy -s a:/pictures /home/user/
Copy all files and directories from the floppy to the backup folder in your home directory. mcopy -s a:/* /home/user/backup/
Remember to use sudo or su -c'command' when issuing these commands.
