Being new to Linux and to Ubuntu, I've taken quite some time to tune it to my needs on my netbook. As I'm now convinced by the OS, I plan to install it on my desktop in the next few days. I was hoping that with Ubuntu One, after a sync, I would find back all my settings on the newly installed machine : system settings, language, list of installed programs (to quickly reinstall the same set), email chat and microblog accounts, Unity launcher shortcuts, etc...
I've just read trought the Ubuntu One website and it seems such a settings-sync feature is not part of it. Is this something that could be done? Is it planned? Is there another way to achieve this same effect?
Thanks in advance for any infos on that.
Jeremy
  • 93
Ubuntu One does not currently support settings sync of arbitrary applications, although we're asked for it a lot. There are a couple of reasons for this. The major one is this: applications need to be written with settings sync in mind. If you take an arbitrary application, which stores its data in a configuration file, then that application is extremely unlikely to notice if Ubuntu One changes that configuration file while the application is running. Indeed, the app will almost certainly overwrite any Ubuntu One-made changes if you change the configuration of the app yourself.
A second issue is that applications do not distinguish between machine-specific settings and user-specific settings. If, for example, your app remembers the last files that it loaded, and you sync that list of recent files with Ubuntu One, what should other instances of that app (on other computers) do if those files are not present? If you save the app's window's position on your huge monitor, and then sync that setting to your netbook, how does the app cope with that? All of these things are certainly handleable within the app, but many apps don't actually realise that they may need to handle them.
The issue here is not that settings sync is in itself hard, but that applications are not really built with the idea that the settings file may contain "impossible to create", unlikely, or contradictory settings, and that the settings file may change at any time.
Some applications are set up to deal with this, and as part of the Ubuntu One application developer programme I'd be happy to talk to any application developer who would like their app to have syncable settings, to work out how best to do it for that app.
Jorge Castro
  • 73,717
sil
  • 4,282
I have a similar problem I have a netbook that has all my current data & settings on it & I want my desktop software & files to be the same.
This is how I fixed my problem.
Let's call the computer with all the original data on it (in my case the netbook) the source & the computer that you want to get the data to the target.
Step 1). Make sure the source system is up to date
sudo aptitude update && sudo aptitude upgrade
Step 2). BACKUP the source user files. There are lots of different ways to do this. This is a good article on backing up. I also have a few articals on backing up in the IT section of my website www.marchiggins.com.
Personally, I choose rsync for this kind of task.
rsync -av /source_directory /target_directory
Depending on the destination you are going to backup your data to you need to run something like this on the source computer;
rsync -av /home/ /media/USB
rsync -av /usr/local /media/USB
cp /etc/apt/sources.list /media/USB
Technically in addition to the above you should also be getting your whole /etc directory & everything in /var (except /var/cache & /var/tmp) but I never bother. As you can see above I do make sure I get a copy of my /etc/apt/sources file.
Then we need to check what additional software is installed on the source computer. Again there are several ways you can do this but this is how I do it.
dpkg --get-selections > /media/USB/installed-software
Will create a file called installed-software that contains all the packages that you have installed.
Step 3). build the target computer & make sure it is the same OS version as the source computer. You can check your version number like this;
cat /etc/lsb-release
Step 4). Once the target has been built, you need to;
setup the users;
sudo adduser
copy the sources.list
sudo cp /media/USB /etc/apt/sources.list
& them make sure everything is up to date, just as we did in step 1)
Step 6). Copy across all of your data, just as we did in step two except in reverse
sudo rsync -av /media/USB /home/
sudo rsync -av /media/USB /usr/local
Now you need to make sure the user ownership permissions on the home directories are set;
sudo chown -R username:username /home/pathtofolder
Step 7). Copy the installed-software file across to the Target computer & run the following to install all the software you had on the source machine to the target machine
sudo aptitude install dselect
cp /media/USB/installed-software /
dpkg --set-selections < installed-software
sudo dselect
Select 3. [I]nstall Install & Upgrade Wanted Packages
At this point you should have two computers that are the same.
From here you can use unison to keep them in sync or rsync. My preference again is rysnc but many people I know use unison & swear by it.
All of these (personal) OS settings are stored in your home folder(~, or /home/username), most (if not all) of them in the form of hidden folders, folders that start with a period, like in ~/.config. You can see such folders if you open your home folder and hit CTRL+H or View > Show Hidden Files.
So if you add your home folder to the Ubuntu One sync, most of personal settings will be transfered to the new machine.
BUT... your installed apps will NOT transfer this way. And most of these settings will only be effective after you install the corresponding app. Also, for such a "hard" copy of settings and config files, its advisable to use exactly the same Ubuntu version in both computers, as well as install the same apps and versions.
That said, my recommended steps are:
  • Install in your desktop the same Ubuntu version thats in your netbook
  • Install in your desktop as many apps and packages as there are currently in your netbook, except those packages and apps that are only relevant in a netbook, like Powertop for example.
  • Power off your desktop
  • In your netbook, add your home folder to Ubuntu One
  • Turn on, login and sync your desktop. Settings will be copied
  • Reboot the desktop, so all setting changes will be effective
Please notice this is not a 100% fail proof procedure. Some settings will not work, while some may even let your desktop a little "weird", since some settings in a netbook simply dont apply in a desktop enviroment (battery management and screen size to name a few). So a few tweaks and re-tunning of settings will still be necessary. But its faster than doing from scratch.
Hope this helps!
MestreLion
  • 20,726
