If so then I am going to install it formatting Windows XP.
Asked
Active
Viewed 2,237 times
It definitely can. Even Aspire One D250 can, which is a bit simpler. But anyway, if you run installation and can see that it goes up to the screen when it offers you "Try" or "Install", that means it can work at the particular hardware. Because by the time you see this screen the Linux Kernel and most subsystems are running. As they are the same that go into your machine this proves it is going to work well.
Ruslan Gerasimov
- 3,895
Yes, you can Install Ubuntu 14.04 LTS on your laptop. Click Here.
You can also install with USB drive.
Click "Replace Windows XP with Ubuntu" for replace.
If you don't want to remove XP, then select "Install Ubuntu alongside Windows XP".
A J
- 11,557
