This is a first for me. I've been having trouble upgrading Ubuntu 12.04. How do I fix this?
sudo apt-get upgrade:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up linux-image-3.8.0-42-generic (3.8.0-42.62~precise1) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-3.8.0-42-generic
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.8.0-42-generic /boot/vmlinuz-3.8.0-42-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.8.0-42-generic /boot/vmlinuz-3.8.0-42-generic
update-initramfs: Generating /boot/initrd.img-3.8.0-42-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.8.0-42-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.8.0-42-generic.postinst line 1010.
dpkg: error processing linux-image-3.8.0-42-generic (--configure):
subprocess installed post-installation script returned error exit status 2
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of linux-image-generic-lts-raring:
linux-image-generic-lts-raring depends on linux-image-3.8.0-42-generic; however:
Package linux-image-3.8.0-42-generic is not configured yet.
dpkg: error processing linux-image-generic-lts-raring (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic-lts-raring:
linux-generic-lts-raring depends on linux-image-generic-lts-raring; however:
Package linux-image-generic-lts-raring is not configured yet.
dpkg: error processing linux-generic-lts-raring (--configure):
I have over 2TB of space remaining on the hard drive. I don't understand:
- gzip: stdout: No space left on device
- MaxReports is reached already
