20
The device map file /boot/grub/device.map is in this format:
(disk) /dev/device
So, for example, on a system with a floppy and a single SCSI disk, the file would look like this:
(fd0) /dev/fd0
(hd0) /dev/sda
I try to display its content :
cat /boot/grub/device.map
I get this error: No such file or directory
Is it renamed or it is a new hierarchy of Linux system?
muru
  • 207,228
The device map is not installed by default with grub2. You can create a device map by typing the following into your console:
sudo grub-mkdevicemap
This will put device.map into the /boot/grub directory.
Fuzzy Analysis
  • 408
Carefully modify /proc/sys/kernel/printk
Set the values to the following (tabs not spaces)
-1  -1  -1  -1
This locks all kernel log levels to zero.
This really cleans up a desktop boot sequence. Not recommended for servers which need these logs.
Birkensox
  • 383
