I'm used to TortoiseHg on Windows. I tried
apt-get install tortoisehg tortoisehg-nautilus
But after the installation I still can't use it by typing
tortoisehg
In the terminal or in the launcher, nor can I right click in a folder and see it in the context menu.
What mercurial GUI works with Unity? If tortoiseHg does, how to use it?
Jader Dias
  • 2,019
You can run TortoiseHG using command thg (or hgtk in older versions), usually in the directory with Mercurial repo.
To use Nautilus plugin, Nautilus must be restarted first by logging out or executing nautilus -q. You should see TortoiseHG in context menu and File menu then.
jnv
  • 3,314
If you've literally typed the above in, you've got the 'g' and 'h' swapped in your apt-get line:
tortoisegh-nautilus
should be
tortoisehg-nautilus
Phasmal
  • 121
If it doesn't show in 13.04 and beyond, I managed to install it rather easily by using the tortoisehg ppa:
sudo add-apt-repository -y ppa:tortoisehg-ppa/releases
sudo apt-get update
sudo apt-get install mercurial tortoisehg
At Ubuntu 13.04 after installing from PPA if you cant get the tortoise menu in nautilus and if you have something like this on your .xsession-errors file at home directory:
(nautilus:2750): Nautilus-Python-WARNING **: g_module_open libpython failed: /usr/lib/libpython2.7.so.1.0: cannot open shared object file: No such file or directory compiz (core) - Info: Unity is fully supported by your hardware. compiz (core) - Info: Unity is fully supported by your hardware. compiz (core) - Info: Starting plugin: opengl ImportError: could not import gobject (error was: '/usr/lib/x86_64-linux-gnu/libpyglib-gi-2.0-python2.7.so.0: undefined symbol: _Py_ZeroStruct')
Maybe this could help you:
https://bugs.launchpad.net/ubuntu/+source/tortoisehg/+bug/1202823
Good luck
