I have a dual boot ubuntu and windows 8. Ubuntu is default os to start up and countdown select the default os to boot If I don't change that before. When I order between ubuntu and windows 8 countdown automatically hide and then, I have to press enter to boot from any highlighted os without time limit.My question is: How can I disable countdown for always and I select which os starts up with using up/down arrow key myself and until I don't select and don't pressing enter, that freeze on grub menu. Any ideas would be my pleasure
Note: There is no /etc/default/grub file in my ubuntu.
Edit: I reinstalled grub (sudo apt-get --reinstall install grub2 grub-pc) and now i have a/etc/default/grub file but the countdown did not stop with this changes:
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT="-1"
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
I delete double quote GRUB_TIMEOUT="-1" around -1 which is automatically added to it and save then running sudo update-grub I get the following warning:
Warning: Setting GRUB_TIMEOUT to a non-zero value when
GRUB_HIDDEN_TIMEOUT is set is no longer supporte
