10
I want to list only running application like: Firefox, gedit, Nautilus, etc. using the command line.
Note: I don't want to list all running process, only applications which are running (say manually launched GUIs).
muru
  • 207,228
Pandya
  • 37,289
A combination of wmctrl and xprop offers many possibilities.
Example 1:
running_gui_apps() {
    # loop through all open windows (ids)
    for win_id in $( wmctrl -l | cut -d' ' -f1 ); do
        # test if window is a normal window
        if  $( xprop -id $win_id _NET_WM_WINDOW_TYPE | grep -q _NET_WM_WINDOW_TYPE_NORMAL ) ; then
            echo "$( xprop -id $win_id WM_CLASS | cut -d" " -f4- )"", window id: $win_id"
        fi
    done
The output could look in this case similar like this:
"Firefox", window id: 0x032000a9
"Gnome-terminal", window id: 0x03a0000c
"Thunar", window id: 0x03600004
"Geany", window id: 0x03c00003
"Thunar", window id: 0x0360223e
"Mousepad", window id: 0x02c00003
"Mousepad", window id: 0x02c00248
"Xfce4-terminal", window id: 0x03e00004
Example 2:
    applications=()
            # filter application name and remove double-quote at beginning and end
            appname=$( xprop -id $win_id WM_CLASS | cut -d" " -f4 )
            appname=${appname#?}
            appname=${appname%?}
            # add to result list
            applications+=( "$appname" )
        fi
    done
    # sort result list and remove duplicates
    readarray -t applications < <(printf '%s\0' "${applications[@]}" | sort -z | xargs -0n1 | uniq)
    printf -- '%s\n' "${applications[@]}"
Output example:
Firefox
Geany
Gnome-terminal
Mousepad
Thunar
Xfce4-terminal
You can add the function to your ~/.bashrc or run it from an script file.
TuKsn
  • 4,440
wmctrl -l could be a thing you wanted. First install it
sudo apt-get install wmctrl
You can also combine it with System Monitor's list, by default it shows "All my processes" which means all process that belong to you as a user.
To have only names of applications, run:
EDIT:
wmctrl -l|awk '{$3=""; $2=""; $1="";  print $0}'
Introduction
The power of xdotool and wmctrl comes out when you need to perform manipulation on the windows, such as moving or resizing. However, I strongly believe that for the purpose of only listing running programs and information about them, xprop and qdbus are two sufficient tools and installing xdotool and wmctrl unless the user wants those for additional functionality - is a purposeless task. In this answer I would like to present two scripting solutions with xprop and qdbus.
Note that I am by no means against xdotool or wmctrl. I've used them extensively myself , but I find them more powerful when combined with other tools. Here are just a few examples where I've used them :
Xprop
The script bellow uses only xprop to extract list of the active windows , filter out only true windows ( not dock type suck as Unity Launcher or Unity Panel ) and display their info:
Demo:
$ bash xprop_windows.sh
XID TYPE    TITLE
56623112| "x-terminal-emulator", "X-terminal-emulator"| "sakura"
81789126| "Navigator", "Firefox"| "Restore Session - Mozilla Firefox"
82002372| "Navigator", "Firefox"| "gui - How do I get a list of running applications by using the command line? - Ask Ubuntu - Mozilla Firefox"
33554444| "gnome-terminal", "Gnome-terminal"| "\"Terminal\""
33554486| "gnome-terminal", "Gnome-terminal"| "\"Terminal\""
Script source:
get_hex_xids()
xprop -root -notype _NET_CLIENT_LIST | \
     awk 'BEGIN{printf "ibase=16"}\
     {gsub(/\,/," ");for(i=1;i<=NF;i++) \
     if ($i~/0x/) printf ";%s",substr(toupper($i),3)   }'
convert_hex2dec()
  HEXIDS=$(get_hex_xids)
  echo $HEXIDS | bc
print_header()
  printf "%s\t%s\t%s\n" "XID" "TYPE" "TITLE"
  printf "%s\n" "--------------------------------"
list_info()
  convert_hex2dec | while read line;
  do
  TYPE=$( xprop -id $line _NET_WM_WINDOW_TYPE | awk -F '=' '{print $2}'   )
  if [ $TYPE != "_NET_WM_WINDOW_TYPE_NORMAL"   ]; then
     continue
  fi
  CLASS=$(xprop -id $line WM_CLASS | awk -F '=' '{print $2}' )
  NAME=$( xprop -id $line _NET_WM_NAME | awk -F '=' '{print $2}'   )
  printf "\n%s|%s|%s\n" "$line" "$CLASS" "$NAME"
  done
print_header
list_info
Qdbus
The code bellow performs essentially the same task, however it filters out applications first, then lists its children windows , and finally provides info about them.
Sample run:
$ bash ~/bin/qdbus_windows.sh
Active :false
Children:
33554486|false|""Terminal""
33554444|false|""Terminal""
Name: Firefox Web Browser
Active :false
Children:
82002372|false|"gui - How do I get a list of running applications by using the command line? - Ask Ubuntu - Mozilla Firefox"
81789126|false|"Restore Session - Mozilla Firefox"
Name: MY CUSTOM TERMINAL
Active :true
Children:
56623112|true|"sakura"
Code itself:
#!/bin/bash
get_window_paths()
  qdbus org.ayatana.bamf  /org/ayatana/bamf/matcher org.ayatana.bamf.matcher.WindowPaths
get_running_apps()
  qdbus org.ayatana.bamf /org/ayatana/bamf/matcher org.ayatana.bamf.matcher.RunningApplications
list_children()
 qdbus org.ayatana.bamf "$1"  org.ayatana.bamf.view.Children
window_info()
for window in "$@" ; do
 XID=${window##*/}
 TYPE=$(qdbus org.ayatana.bamf $window org.ayatana.bamf.window.WindowType)
 NAME="$(qdbus org.ayatana.bamf $window org.ayatana.bamf.view.Name)"
 ACTIVE=$(qdbus org.ayatana.bamf $window org.ayatana.bamf.view.IsActive)
 MONITOR=$(qdbus org.ayatana.bamf $window org.ayatana.bamf.window.Monitor)
# printf "%s|%s|%s|%s\n" $TYPE $MONITOR $ACTIVE "$NAME"
 printf "%s|%s|\"%s\"\n" $XID $ACTIVE "$NAME"
done
window_paths=( $( get_window_paths | tr '\n' ' ') )
apps_list=( $( get_running_apps | tr '\n' ' ' ) )
for app in ${apps_list[@]} ; do
#echo $app
  printf "Name: "
  qdbus org.ayatana.bamf $app org.ayatana.bamf.view.Name
  printf "Active :"
  qdbus org.ayatana.bamf $app org.ayatana.bamf.view.IsActive
  printf "Children:\n"
#  list_children $app
  windows=( $( list_children $app | tr '\n' ' ' ) )
  window_info "${windows[@]}"
  printf "%s\n"  "--------------"
done
A bit simpler command but requires filtering out the output uses Unity's window stack dbus interface. Here is essentially a function I have in my .mkshrc
window_stack()
  qdbus --literal com.canonical.Unity.WindowStack
        /com/canonical/Unity/WindowStack  \
        com.canonical.Unity.WindowStack.GetWindowStack | \
  awk -F '{' '{gsub(/\}|\]|,/,"");gsub(/\[/,"\n");print $2}' | \
  awk '!/compiz/&&!/^$/ && $4!="\""$3"\""  { L[n++] = $0 }\
       END { while(n--) print L[n] }'
Sample run:
$ window_stack
Argument: (usbu) 56623112 "x-terminal-emulator" true 0
Argument: (usbu) 82002372 "firefox" false 0
Argument: (usbu) 81789126 "firefox" false 0
Argument: (usbu) 33554486 "gnome-terminal" false 0
Argument: (usbu) 33554444 "gnome-terminal" false 0
Examples of qdbus usage:
