Back in my (sucky) Windows days, I used the tree command to view the file hierarchy in a pretty display. I am aware of the find command, but to actually process any data in my clogged 241,416 folders/files from just checking each line is as possible as time travelling...
./build/CMakeFiles/cmake.check_cache
./build/CMakeFiles/Makefile.cmake
./build/CMakeFiles/CMakeTmp
./build/CMakeFiles/TargetDirectories.txt
./build/CMakeFiles/compilerid.dir
./build/CMakeFiles/compilerid.dir/depend.make
./build/CMakeFiles/compilerid.dir/flags.make
./build/CMakeFiles/compilerid.dir/DependInfo.cmake
./build/CMakeFiles/compilerid.dir/link.txt
./build/CMakeFiles/compilerid.dir/build.make
./build/CMakeFiles/compilerid.dir/cmake_clean.cmake
./build/CMakeFiles/compilerid.dir/main.o
./build/CMakeFiles/compilerid.dir/CXX.includecache
./build/CMakeFiles/compilerid.dir/progress.make
./build/CMakeFiles/compilerid.dir/depend.internal
./build/cmake_install.cmake
./build/CMakeCache.txt
./build/Makefile
./build/compilerid
./CompilerID.kdev4
./.kdev4
./.kdev4/CompilerID.kdev4
./main.cpp
Output of find on one folder holding the files of a one-file, incomplete C++ project
On Windows, the tree command gave a diagram-like output that is human readable
Screenshot of tree command in command prompt Screenshot of the pretty tree command
So, my question is, is there anything graphically close to the Windows/DOS tree command?
Same command exist. To install, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo apt-get install tree
Mitch
  • 109,787
You have tree command in linux. All you have to do is install it. It works very similar to the one in windows.
answerSeeker
  • 901
  • 26
