When I try to convert a video - specifically, a Video Object (".vob") file - to MPEG-4, WinFF which I assume is a frontend for ffmpeg and avconv, but it tells me:
`Unknown encoder 'libvo_aacenc'`
The full text from Terminal is:
avconv version 9.13-6:9.13-0ubuntu0.14.04.1, Copyright (c) 2000-2014 the Libav developers
built on May 9 2014 13:34:03 with gcc 4.8 (Ubuntu 4.8.2-19ubuntu1)
[mpeg @ 0x1924160] max_analyze_duration reached
Input #0, mpeg, from '/media/gregoryopera/Movies/Get a Horse!.vob':
Duration: 00:00:04.37, start: 0.221156, bitrate: 631225 kb/s
Stream #0.0[0x1e0]: Video: mpeg2video (Main), yuv420p, 720x576 [PAR 64:45 DAR 16:9], 9800 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0.1[0x20]: Subtitle: dvdsub
Stream #0.2[0x21]: Subtitle: dvdsub
Stream #0.3[0x22]: Subtitle: dvdsub
Stream #0.4[0x23]: Subtitle: dvdsub
Stream #0.5[0x24]: Subtitle: dvdsub
Stream #0.6[0x25]: Subtitle: dvdsub
Stream #0.7[0x26]: Subtitle: dvdsub
Stream #0.8[0x27]: Subtitle: dvdsub
Stream #0.9[0x28]: Subtitle: dvdsub
Stream #0.10[0x29]: Subtitle: dvdsub
Stream #0.11[0x2a]: Subtitle: dvdsub
Stream #0.12[0x2b]: Subtitle: dvdsub
Stream #0.13[0x80]: Audio: ac3, 48000 Hz, 5.1, fltp, 384 kb/s
Stream #0.14[0x81]: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
Stream #0.15[0x82]: Audio: ac3, 48000 Hz, 5.1, fltp, 384 kb/s
Stream #0.16[0x83]: Audio: ac3, 48000 Hz, 5.1, fltp, 384 kb/s
Stream #0.17[0x84]: Audio: ac3, 48000 Hz, 5.1, fltp, 384 kb/s
Press Enter to Continue*
When I press "Enter", Terminal closes and my conversion is canceled.
And before anyone says it - I did find the other answer relating to this same question here on Ask Ubuntu... However that guy compiled it from scratch, which I do not want to do (for a start, I wouldn't know where to begin!)...
