I was watching a tutorial that needs komodo edit. I downloaded it but cant get the installer to run the way you just click the extraction file in windows. Any suggestions on what to do, maybe a solution from the terminal?
Asked
Active
Viewed 1,438 times
U can try install it from repositores open a terminal type command i write u below and read instaruction on the screen :)
alt+ctrl+t
type sudo add-apt-repository ppa:mystic-mirage/komodo-edit
then type
sudo apt-get update
after finish updating type sudo apt-get install komodo-edit
if instalation is done u can run it from menu or type in terminal komodo-edit
Cacus
- 106
- 7
