61
When I run a program (for example grep or ls) without a pager, its output is colored. However when I run it piping its output to less, no colors are shown.
For example, this command outputs colored output:
grep -r something
but this doesn't:
grep -r something | less
Why? How can I see colors through less?
There are two problems here:
  • Commands like ls —which auto-detect the colour support— don't find support from pipes
  • less is set to just display colour codes by default.
Both can be overcome but it's a bit clunky:
ls --color=always | less -R
This isn't ls specific. Many commands that support colour also have an override argument.
A slightly more in-depth answer is that ls is checking whether or not its STDOUT belongs to a real terminal or not. When you pipe things around, the STDOUT is set to the STDIN of the next command.
You can see this at work in the ls source code. It's using the isatty command (a core POSIX interface) to work out what the situation is:
  • Are colours on by default:
        print_with_color = (i == color_always
                            || (i == color_if_tty
                                && isatty (STDOUT_FILENO)));
  • Do we try to output in multiple columns:
    if (format == long_format)
      format = (isatty (STDOUT_FILENO) ? many_per_line : one_per_line);
    if (isatty (STDOUT_FILENO))
        format = many_per_line;
        set_quoting_style (NULL, shell_escape_quoting_style);
        qmark_funny_chars = true;
    else
        format = one_per_line;
        qmark_funny_chars = false;
grep does a very similar thing, unless explicitly overridden, it'll detect colour support, with isatty:
color_option = isatty (STDOUT_FILENO) && should_colorize ();
Oli
  • 299,380
If you're interested in colors in less more generally, you might want to look at lesspipe.sh. See, for example, https://github.com/wofr06/lesspipe.
lesspipe.sh is an input filter for the pager less as described in less's man page. The script runs under a ksh-compatible shell (e.g. bash, zsh) and allows you to use less to view files with binary content, compressed files, archives, and files contained in archives.
It will also colorize shell scripts, perl scripts, etc. similarly to a text editor, but without the use of any "preprocessing" program to do the colorizing.
simbabque
  • 777
DaveEmme
  • 261
@oli's answer relies on you being able to provide appropriate flags to the command that produces the colors. That can be difficult if commands are buried in scripts and the like, and it requires working out how to provide appropriate flags separately for various commands that know how to produce ANSI escapes when the terminal environment says they can.
@DaveEmme's answer tells you that you can use lesspipe to colorize output from whatever source, but as far as I know it won't retain the color from commands that already produce it when output goes to the terminal.
If you already have a command that works just fine in your terminal, then it's nice to be able to run that command in such a way that color escapes are kept regardless of the output being piped, so you can feed that into less -R.
unbuffer does this for you. On debian at least you get it with sudo apt install expect-dev.
You can then do:
unbuffer [command] |& less -R
Using |& instead of | might be an unnecessary detail, but it means STDERR gets piped to less as well as STDOUT.
Thanks to https://superuser.com/a/1260695/229226 for this.
mc0e
  • 368
