-2
Okay, I decided to migrate from MySQL Server 5.5.37 to Percona Server 5.6. I ended up removing MySQL Server by the following:
sudo apt-get --purge remove mysql-server mysql-server-5.5 mysql-server-core-5.5 mysql-client mysql-client-core-5.5 mysql-common
sudo apt-get autoremove
sudo apt-get autoclean
rm -rf /var/lib/mysql
rm -rf /etc/mysql
Now here is my problem, when I try to install MySQL Server 5.6 it goes through its process and when it asks me for a password, it comes up with Cannot set MySQL "root" password. After it "installs" MySQL wont start up and I get permission denied?.
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 35 not upgraded.
brandon@brandon-DB:~$ sudo apt-get install mysql-server
The following extra packages will be installed:
libdbd-mysql-perl libdbi-perl libmysqlclient18 libterm-readkey-perl mysql-client-5.5     mysql-client-core-5.5 mysql-common
Suggested packages:
libmldbm-perl libnet-daemon-perl libplrpc-perl libsql-statement-perl tinyca mailx
The following NEW packages will be installed:
0 upgraded, 10 newly installed, 0 to remove and 35 not upgraded.
Need to get 0 B/8,955 kB of archives.
After this operation, 96.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Preconfiguring packages ...
Selecting previously unselected package mysql-common.
(Reading database ... 167760 files and directories currently installed.)
Preparing to unpack .../mysql-common_5.5.37-0ubuntu0.14.04.1_all.deb ...
Unpacking mysql-common (5.5.37-0ubuntu0.14.04.1) ...
Selecting previously unselected package libmysqlclient18:amd64.
Preparing to unpack .../libmysqlclient18_5.5.37-0ubuntu0.14.04.1_amd64.deb ...
Unpacking libmysqlclient18:amd64 (5.5.37-0ubuntu0.14.04.1) ...
Selecting previously unselected package libdbi-perl.
Preparing to unpack .../libdbi-perl_1.630-1_amd64.deb ...
Unpacking libdbi-perl (1.630-1) ...
Selecting previously unselected package libdbd-mysql-perl.
Preparing to unpack .../libdbd-mysql-perl_4.025-1_amd64.deb ...
Unpacking libdbd-mysql-perl (4.025-1) ...
Selecting previously unselected package libterm-readkey-perl.
Preparing to unpack .../libterm-readkey-perl_2.31-1_amd64.deb ...
Unpacking libterm-readkey-perl (2.31-1) ...
Selecting previously unselected package mysql-client-core-5.5.
Preparing to unpack .../mysql-client-core-5.5_5.5.37-0ubuntu0.14.04.1_amd64.deb ...
Unpacking mysql-client-core-5.5 (5.5.37-0ubuntu0.14.04.1) ...
Selecting previously unselected package mysql-client-5.5.
Preparing to unpack .../mysql-client-5.5_5.5.37-0ubuntu0.14.04.1_amd64.deb ...
Unpacking mysql-client-5.5 (5.5.37-0ubuntu0.14.04.1) ...
Selecting previously unselected package mysql-server-core-5.5.
Preparing to unpack .../mysql-server-core-5.5_5.5.37-0ubuntu0.14.04.1_amd64.deb ...
Unpacking mysql-server-core-5.5 (5.5.37-0ubuntu0.14.04.1) ...
Processing triggers for man-db (2.6.7.1-1) ...
Setting up mysql-common (5.5.37-0ubuntu0.14.04.1) ...
Selecting previously unselected package mysql-server-5.5.
(Reading database ... 168116 files and directories currently installed.)
Preparing to unpack .../mysql-server-5.5_5.5.37-0ubuntu0.14.04.1_amd64.deb ...
Unpacking mysql-server-5.5 (5.5.37-0ubuntu0.14.04.1) ...
Selecting previously unselected package mysql-server.
Preparing to unpack .../mysql-server_5.5.37-0ubuntu0.14.04.1_all.deb ...
Unpacking mysql-server (5.5.37-0ubuntu0.14.04.1) ...
Processing triggers for ureadahead (0.100.0-16) ...
Setting up libmysqlclient18:amd64 (5.5.37-0ubuntu0.14.04.1) ...
Setting up libdbi-perl (1.630-1) ...
Setting up libdbd-mysql-perl (4.025-1) ...
Setting up libterm-readkey-perl (2.31-1) ...
Setting up mysql-client-core-5.5 (5.5.37-0ubuntu0.14.04.1) ...
Setting up mysql-client-5.5 (5.5.37-0ubuntu0.14.04.1) ...
Setting up mysql-server-core-5.5 (5.5.37-0ubuntu0.14.04.1) ...
Setting up mysql-server-5.5 (5.5.37-0ubuntu0.14.04.1) ...
start: Job failed to start
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing package mysql-server-5.5 (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.5; however:
  Package mysql-server-5.5 is not configured yet.
dpkg: error processing package mysql-server (--configure):
dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.19-0ubuntu6) ...
No apport report written because the error message indicates its a followup error from a previous failure.
 mysql-server-5.5
 mysql-server
I have all my database/tables dumped and on a seperate HDD. This is also a Dev Machine and not my main Production Machine. I also backed up the MySQL_Config and MySQL_Data.
EDIT: I was able to get MySQL Server 5.6 Installed on my machine!
Configure the mysql-server-5.5 and then install mysql-server.
sudo dpkg --configure mysql-server-5.5
