I have a Asus S56CA laptop. When I bought this laptop, it came prinestalled with Windows 8 wich I updated to 8.1. I soon decided that Windows wasn't right for me and decided to use my old Ubuntu 12.04 LTS disk to install Ubuntu and experienced no problems with this. I then updated this to Ubuntu 14.04 LTS using sudo update-manager -d.
After this update I have had troubles waking up my laptop after closing the lid. I am either receiving a black, blank screen where all I can see is the mouse (The mouse can be moved) or the lock screen which I cannot interact with at all (Entering Password, moving mouse etc). I was wondering if anyone else has had this problem and how they got around it. If not, does anyone know a way to fix this and stop it from happening in the future.
Thanks all.
EDIT: sudo fdisk -l:
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x00035215
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048   968617983   484307968   83  Linux
/dev/sda2       968620030   976771071     4075521    5  Extended
Partition 2 does not start on physical sector boundary.
/dev/sda5       968620032   976771071     4075520   82  Linux swap / Solaris
df -h:
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda1       455G   14G  418G   4% /
none            4.0K     0  4.0K   0% /sys/fs/cgroup
udev            2.0G  4.0K  2.0G   1% /dev
tmpfs           393M  1.2M  392M   1% /run
none            5.0M     0  5.0M   0% /run/lock
none            2.0G  580K  2.0G   1% /run/shm
none            100M   40K  100M   1% /run/user
This can be a temp. fix by trying to avoid suspending. Do the following: Go to Dash then System Setting, power and the choose When lid is closed do nothing.
Daniel
  • 465
