I attempted to load Windows 8 and Ubuntu alongside each other and it was working well until my Ubuntu installation completed and I restarted the computer. Now I can't get past this error:
Minimal bash-like line editing is supported.
For the first word, TAB lists possible command completions.
Anywhere else TAB lists possible device or file completions.
Grub>
How do I fix this? I'm not a computer person. Talk me through it. I'm using GNU GRUB version 2.02 beta 2-9.
If your goal is to fix Windows, this may help you, or at the very least it will save someone else about 6 hours of googling:
I had the same problem after trying to dual-boot Windows 8 and Ubuntu 14.04 then deleting the Ubuntu partitions. I tried using the usual bootrec /fixmbr, /fixboot, etc.
None of this worked. The problem is that you have to first move to the EFI partition, rename the BCD file, then run the bootrec /fixmbr, bootrec /fixboot, and bootrec /rebuildbcd commands.
See this tutorial: http://www.fixedbyvonnie.com/2013/12/how-to-repair-the-efi-bootloader-in-windows-8/#.VAQWdDJdU4o
Then after step 3:
Enter: bootrec /fixmbr [Press Enter]
Enter: bootrec /fixboot [Press Enter]
Enter: bootrec /rebuildbcd [Press Enter]
It will ask you which installations you want to rebuild the BCD file for. I just entered All. Then I restarted and all was back to normal. Hope that helps.
αғsнιη
  • 36,350
