12
I tried adding tomboy in System -> Preferences -> Startup Applications, but this causes the "Search All Notes" window to appear every time I log in. I just want it to run in the notification area so that I can use it later via hotkeys or its notification area icon popup menu.
ændrük
  • 78,496
There is an undocumented option --icon that makes tomboy start without showing a window. It HAD a bug (bug #566421), which has now been resolved.
Also, you can use the tomboy applet: Right click on the panel, choose “Add to Panel” and select “Tomboy Notes“. The panel applet looks similar to the notification area icon and provides the same functionality (hotkeys and popup menu).
TomKat
  • 3,878
Method 1.
Go to System Tools >> Preferences >> Startup Applications and Click "Add"
Fill in the windows
Command: tomboy --indicator
Comment: Take notes, link ideas, and stay organized
Then click "Add"
Method 2
Open the dash and start typing Startup Applications.
When it shows up, click on it to open it. Click "Add", then continue from "Fill in the windows" above.
Method 3.
Open a terminal (Ctrl+Alt+T) and type "gnome-session-properties" to launch the startup Applications manager. Click "Add", then continue from "Fill in the windows" above.
labinnsw
The search menu will appear if the panel is not ready. Use a script like #!/bin/sh && /bin/sleep 18 && /usr/bin/tomboy instead of plain tomboy
Jorge Castro
  • 73,717
daithib8
  • 3,361
"I just want it to run in the notification area" I want Tomboy's search selection yellow "Tomboy Notes" icon to always appear in the bottom panel strip of my Linux Mint 17 Qiana, Cinnamon 2.2.16 program. Problem I had: Icon would sometimes be on panel and sometimes not, but would always appear after 2 or more hours later. Drove me crazy. I have this bottom panel strip set to minimum height.
Solution: I found that if I increased the height of the panel strip, The icon would appear instantly.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
