12
Since I installed ubuntu 14.04 I can no longer play wmv, wma or 3gp files with any player ( gxine - vlc - totem - etc.)
I have installed Ubuntu restricted extras and ffmpeg.
My friends, I found the solution, and the solution is remove all gstreamer packages, then reinstall it.
Erick
  • 449
I have the same problem with Xubuntu 14.04, too. Solution above didn't work for me. The only workaround I found was to play wmv files using mplayer from terminal (since skinned version fails to load).
Like mplayer [filename]
Hope it helps.
EDIT: found out, that XBMC can play wmv files as well.
vlad saling
  • 121
I had a similar issue.
Deleting the ~/.gstreamer-0.10 solved the issue. You may need to logout and in again.
To Do
  • 15,833
I had same problem with VLC in Ubuntu 14.04 . and solved the problem by:
1] install last ubuntu-restricted-extras -> sudo apt-get install ubuntu-restricted-extras
2] Then upgrade vlc -> sudo apt-get upgrade vlc
ahmed hamdy
  • 869
I had this same problem too, after some search I found this bug report for vlc. I have installed SMPlayer from software center, now I can play those video files without any problem. you can try it too, see if it solve the problem.
raz
  • 1,882
