22
I have several .dvd files which were created using OpenShot Video Editor. To export the videos from OpenShot, I used the DV-NTSC widescreen and DV-PAL Widescreen property.
Can anyone tell me how I can burn these *.dvd files into a DVD that can be played with my external Sony CD/DVD 5.1 Player which is connected to a TV?
Learner
  • 1,181
5 Answers5
28
What you do need to make a DVD work for a DVD Player is a program called DeVeDe NG.
1 - Open up Ubuntu Software Centre and in the search field type devede and it will be shown in the results.
2 - Install that program.
3 - Start the program and then you will see a series of options.
4 - choose Video DVD: Creates a video DVD suitable for all DVD home players
5 - You need to add the file to create an .ISO so it will work in a DVD Player.
6 - In the Files section, click ADD and then search for the file you want.
7 - Once you have added the file, click on it and then click on Properties
8 - If the file exceeds 99%, then click on Adjust Disc Usage
9 - Click on the Video Options tab and select Scale Picture so there are no black bars (Letterbox Effect)
10 - Click Forward (check 2nd picture) and choose where you want to save the finished .ISO
11 - Click OK
The .ISO will now start to be processed, once it has finished you will then need to burn the .ISO to a blank DVD. I advise that you burn the .ISO at the slowest speed possible to ensure the best results.
AnotherKiwiGuy
  • 4,482
  • 22
  • 39
scouser73
  • 4,344
Open Shot's .dvd files are basically the same as .vob files for DVD creation. However Open Shot has no DVD authoring module yet.
In the meantime it is recommended to import the .dvd files to a dvd authoring application such as:
Takkat
  • 144,580
If its a standard format, you should be able to right-click the file and select 'burn to disc'. Although I haven't heard of the .dvd file before.
I've found as a new user of Ubuntu that the brasero disc burner is slightly more difficult to get a hold of. It's not available on the software centre, like it says on the tutorial on the Ubuntu website. However I did find it here on web:
http://www.ubuntuupdates.org/package/core/yakkety/universe/base/brasero
You can download 32bit and 64bit packages, personally I selected the option to use APT Install.
Obviously you will still need create the iso image first in DeVeDe...Hopefully this will help at least one person.
MikeJNR
I use DeVeDe for making the dvd image file, and then I burn it with Brasero(comes included). I have been having trouble burning discs with devede but making the image file with that program and burning it with another works fine just make sure you know how to get to the image file!
