So I installed Ubuntu about a week ago after finally getting around to sorting out my partitions. Everything has gone great except that I get screen tearing on anything that goes fullscreen. I've searched around and tried loads of different solutions but none have worked. My GFX card is a nVidia GT 650M, I hope someone has a solution.
bain
  • 12,200
Screen tearing is a very annoying problem and can be caused by different things. Check if your vsync is enabled and check whether your monitor's refresh frequency is set to the same value as the software value. A quick search online shows that the NVidia 650 has this problem for quite a few people. I advise you to search around and see what works for you. Different people report different methods of dealing with it.
It greatly depends on the vendor of the GPU, what other hardware, drivers and settings you are using.
Jakke
  • 1,108
  • 13
  • 26
First install CompizConfig-Settings-Manager by
sudo apt-get install compizconfig-settings-manager
Open CompizConfig-Settings-Manager find Composite and check it. Now Click Composite and uncheck the box of Unredirect Fullscreen Windows. Close CompizConfig-Settings-Manager.
sta
  • 153
If you are still having the issues with video tearing using your Nvidia card you can run the following in a terminal: nvidia-settings --assign CurrentMetaMode="nvidia-auto-select +0+0 { ForceFullCompositionPipeline = On }"
Worked great on a few of my machines running on Ubuntu 16.04.
Assuming you are using one video card, Alternatively you can try this config file edit in the file located at: /etc/X11/xorg.conf
Section "Device" Identifier "Device0" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "GeForce GTX 650" Option "RegistryDwords" "PerfLevelSrc=0x2222" Option "TripleBuffer" "True" EndSection
You can change the performance level value to "PerfLevelSrc=0x2233" if your video card does not like the full performance setting above.
MTND G
This may Also help...
Do a complete removal of existing Nvidia drivers and Config's.
I use Terminal booting to the grub recover option in the boot menu. Then an apt-get purge method, but you might want to look this up as I accidently put a * at he the end of my command and 'FURAR'ed my system once!!!
I was there after able to install Nvidia again in a normal boot with good results. I also added the Nvidia control panel (nvidia-settings) to get better control over the card functions. Seems too much is left behind and not removed installing the drivers over the previous drivers, thus causing problems and having no Idea where you are with the drivers,
Much said about this in the search results...Perhaps too much!!!... and not very concise.
