Is there a way to tell what encoding is used for the name and content of a file? Both GUI and terminal solutions (preferred) are fine. Thanks and regards!
Asked
Active
Viewed 2,010 times
You could try
chardet <<<filename
The chardet program can try to guess the encoding of the stream on stdin, and <<< is the mean by which bash use a string as stdin, the same as
echo filename | chardet
For a whole directory content you can use
ls dir | chardet
EDIT
I forgot about the content, but is almost the same:
chardet <filename
or
cat filename | chardet
or for all the files in dir
cat dir/* | chardet
enzotib
- 96,093
If you mean mime-encoding you could try
file --mime-encoding filename for the content of the file.
Marcel
- 612
