We use upstart to manage our services on our Ubuntu servers. They produce logs which are logged out to /var/log/upstart/SERVICE_NAME.log
Then daily, the log files are rotated using the logrotation script which comes with 12.04 LTS:
/var/log/upstart/*.log {
daily
missingok
rotate 7
compress
notifempty
nocreate
The problem is that while logrotate moves the files, it doesn't appear to signal to upstart to close and reopen the files, leaving the upstart process writing to a delete PID.
init 1 root 8w REG 202,1 64 2431 /var/log/upstart/dbus.log.1 (deleted)
init 1 root 13w REG 202,1 95 2507 /var/log/upstart/acpid.log.1 (deleted)
init 1 root 14w REG 202,1 127 17377 /var/log/upstart/whoopsie.log.1 (deleted)
init 1 root 36w REG 202,1 122 6747 /var/log/upstart/SERVICE_NAME.log.1 (deleted)
init 1 root 37w REG 202,1 30 6762
Obviously I could redirect the output from my own services to other log files, but the problem would still be there for the system processes. Also I would rather not have to build more infrastructure than what I need.
