So I have two flash drives in, one is running Ubuntu as a live cd and I'm using that to install Ubuntu on the other. I've gone through the download process, clicked on "something else" and now I have to partition my flash drive. I don't know how to do this. What exactly do I do now?
Thank you guys so much! That link helped a lot, I'm just not sure if I have quite the right amount of space partitioned to each thing(I'm using a 14gig flashdrive) but I think I'm close enough. Does it matter if the colors that show how much space is is used are swapped with the ones in the link?
Follow the option for manual partitioning, however be sure that you are operating with the second USB flash device, like /dev/sdb1. Most likely you are booting from the /dev/sda which is installation media, so now add/create a partition on /dev/sdb to install to.
