Is there a way of removing it from startup?
I don't need it and I'm not using evolution at all.
- 8,925
If you want to remove evolution-data-server, it will remove these at least (tested in 16.04)
The following packages will be REMOVED:
evolution-data-server gdm3 gnome-contacts gnome-shell libfolks-eds25
0 upgraded, 0 newly installed, 5 to remove and 378 not upgraded.
After this operation, 15.8 MB disk space will be freed.
So, the better treatment is a bit nasty, but it works!
Nasty Hack!
Rename Evolution binary folder, so that it won't be found! What works for me is these
sudo mv /usr/lib/evolution-data-server /usr/lib/evolution-data-server-disabled
sudo mv /usr/lib/evolution /usr/lib/evolution-disabled
That's it! Now, I can at least use the system.
Notes: If you disable evolution this way, you won't be able to use calender syncs or other fancy (useless for me) stuff.
Less dirty hack (update)
Looks like more and more people are unsatisfied with evolution lately. But in my current setup, I don't rename the folder. Instead I just remove the executable bit and it works.
For disabling calendar process, I used
sudo chmod -x /usr/lib/evolution/evolution-calendar-factory
The good thing with this method is other evolution service can still work (they start and runs)
Repeat the same process for evolution-source-registry and evolution-addressbook-factory if you want to shut them up too!
I didn't have Evolution installed, but still had this running as well.
Remove the package evolution-data-server via the Software Center. Or type this into a terminal: sudo apt-get purge evolution-data-server. Then log out and back in, it should be gone.
N.b. This worked for me in 14.04 and 16.04 if using the Unity desktop; it does not, however, in 18.04, as a lot of critical gnome packages depend upon it
- 8,925
You can mask the units using systemd (tested on Ubuntu 18.04, Unity):
systemctl --user mask evolution-addressbook-factory.service evolution-calendar-factory.service evolution-source-registry.service
After logout/login the services will not be started anymore.
- 410
Ubuntu won't allow you to remove evolution-calendar-factory because this is a library shared by many programs.
If you try to execute: sudo apt-get purge evolution-data-server or sudo apt-get remove evolution-data-server your system will be broken!
You can test these commands in the terminal using the -s flag (simulate) (be careful!)
sudo apt-get remove evolution-data-server -s
And you will see that the ubuntu-gnome-desktop would be removed, and after next reboot, you won't be able to log in to the system any more. :(
So, do not remove evolution-data-server.
If you're using Gnome or Gnome-Shell, it seems you cannot remove evolution-data-server, since it will remove also the entire DE
root@europa:/home/user# apt remove evolution-data-server
Reading package lists... Done
Building dependency tree
evolution-data-server gdm3 gnome-contacts gnome-shell gnome-shell-extension-weather gnome-shell-extensions libfolks-eds25
0 upgraded, 0 newly installed, 7 to remove and 6 not upgraded.
After this operation, 17,5 MB disk space will be freed.
Do you want to continue? [Y/n] n
If you still want to get rid of those annoying and resource-greedy processes, you can just delete (or, better, rename) the directory of their executables:
root@europa:/home/user# mv /usr/lib/evolution /usr/lib/evolution_DISABLE
Then kill all the running processes:
root@europa:/home/user# for procname in $(ps aux | grep evolution | awk -F'/' '{print $NF}' | grep evolution | grep -v grep); do killall $procname; done
This way, Gnome won't be able to restart them anymore.
Worked for me without any visible collateral damage.
- 141
So, if you think the above answers are too poisonous to your system (ripping out gnome-desktop prereqs, deleting/renaming packaged files? No thanks!), I may have a solution for you.
Create ~/.config/upstart/kill-evolution-services.conf and populate it with the following code. Be sure to replace USER with your username.
start on desktop-start
stop on desktop-end
script
ME=USER
GIVEUP=60
while ! pgrep -u "$ME" -f '^/usr/lib/evolution/evolution'; do
GIVEUP=$((GIVEUP - 1))
if test $GIVEUP = 0; then
break
fi
sleep 1
done
pkill -u "$ME" -f '^/usr/lib/evolution/evolution'
end script
This will run on login, wait until the evolution services have started (up to 60s, adjustable with GIVEUP), then kill them. From what I've seen (on 16.04) they'll stay dead until you interact with some application that needs them, like gnome-calendar (the app, not the indicator). To counter this, you can add the following to crontab (run "crontab -e" from terminal). Again, be sure to replace USER with your username.
*/1 * * * * pkill -u USER -f '^/usr/lib/evolution/evolution'
This will try to kill evolution services once per minute.
So we're rid of evolution services without driving apt crazy or even calling sudo. Allegedly the memory usage issues with these services has been fixed in Gnome 3.20, but Ubuntu has yet to backport them to 3.18. Keep an eye on https://bugs.launchpad.net/ubuntu/+source/indicator-datetime/+bug/1589605, even though it has nothing to do with indicator-datetime, from what I can tell. The indicator runs fine without evolution services at the lightdm login, anyway.
If any of this ends up having side effects on your configuration, you can simply delete ~/.config/upstart/kill-evolution-services.conf and remove the crontab line (again, crontab -e from a terminal). Then log out and back in for good measure, if you're paranoid.
- 4,171
- 391
In 22.04 I've done the work with:
sudo rm -rf /etc/xdg/autostart/evolution-alarm-notify.desktop
- 121
I didn't try to remove it since I run gnome, but what did work was to copy the systemd unit files to /etc and set ExecStart to /bin/ls:
cp /usr/lib/systemd/user/evolution-calendar-factory.service /etc/systemd/user/
cp /usr/lib/systemd/user/evolution-source-registry.service /etc/systemd/user/
and in the unit file make sure ExecStart is /bin/ls:
ExecStart=/bin/ls
Then do
systemctl --user daemon-reload
systemctl --user restart evolution-source-registry
systemctl --user restart evolution-calendar-factory
Note that doing "systemctl disable --user evolution-source-registry" seemed to have no effect.
- 1
